What does Event Category A DCS 1,0-5,0W/KG mean
(Stefan) #1
I have registered for my firt event, the Tour of Watopia:Stage 3 (open) with some intervals, sprints, etc. The range of W/kg of 1-5 is a bit confusing, but I guess its because there are intervals, right?
I assume Zwift will set the Watt not the %FTP, correct?
(Gerrie Delport TeamZF) #2
Hi Stefan,
So the range W/kg of 1-5 mean it is for every one, this is a group workout, so your FTP will determine the required power (w) for each interval.
(Stefan) #3
Thanks !!! How can I see at what %FTP the interval sections will be set? In the event calendar I can only see the Watt.
(Gerrie Delport TeamZF) #4
If you click on the link I posted you can enter your FTP and it will calculate the required power (watts)
(Stefan) #5
Thanks. For a workout this is understood. Let’s see how this works in the Zwift event.
(Gerrie Delport TeamZF) #6
It will be the same as a workout except you will be doing it will other people.
