Running bkool pro. Reads very high , effort certainly not 600 watts and rate of acceleration also impossible. My ftp nearer 200. What’s causing the problem? Thanks
The first question always seems to be: Have you calibrated the unit using the manufacturer’s app?
From bkool website pro2 is calibrated once at factory unless any problems cause cal data to be erased.
Also device works fine on bkool app?
Thanks for any advice. Easy option seems to be to leave zwift and use bkool app
