Warning Message
Hey everyone,
In my last few rides I have seen a warning message pop up on the screen. It only lasts for a quick second and today I had to hold my computer to actually try and see what says. It says that its detected tire slippage and it will drop my watts until it is back to normal.
I am using a cyclops fluid 2 trainer and I checked the trainer/tire and everything seems fine. I even checked the tire pressure to make sure it was ok as well. The message normally occurs when I am sprinting or climbing.
Thanks in advance for any advice or input.
Hi Jim,
If you aren’t already, try using a USB extension cable to bring the ANT+ dongle closer to your speed sensor. Interference can cause data-loss during transmission and might bring the warning up.
