Hi all,
I’m considering buyng a Wahoo Kickr 2018 but struggling for space so every cm counts! This is where I need your help, please can I ask anybody who already has a Wahoo Kickr to have a quick measure and confirm the distance between the Middle of the quick release skewer and the back of the unit?
I’ve attached an image with a red line on it, the red line represents the bit I need the measurement of.
Appreciate your help!
Thank you!
Here you are … my Kickr 2018 - according my humble measurement it’s 31,6cm (± 1mm which I hope doesn’t matter )
Thanks so much for taking the time to measure and post the photos @Godmother_Fox
Looking at the measurement above it’ll save me approx. 4 cm compared to having the rear wheel mounted… unfortunately I was hoping for a 10cm saving. Might need to look at the Kickr climb as well to get it all to fit (eek).
The Core might be a bit more compact. I can measure mine if you want. I also have the Climb, so I can tell you the space that saves as well.
Edit: Just checked for kicks. About 29.2 cm from skewer to back leg of the Core and about 20 cm from skewer to front of the Climb.
Andy - you are welcome. No problem at all. I have a Kickr Climb also … and just did some (rough) measurement … from my humble point of view it should save you another 10-11cm.
See photos. Hope it helps … let me know if you need anything else …
Edit/additional comment - the wheel is put on Climb’s axle and Climb is at flat/0 degree position
If you’re somewhat handy, you could always build yourself a static skewer holder that replicates the position of your fork when the wheel is on. Some wood, a saw and a drill would be all that’s needed. You’d get the space savings of the Climb without the cost.
@Godmother_Fox @Raiontzukai Thank you, far too helpful.
I’ll review all this later on or over the weekend, appreciate your efforts.
