Wahoo Kickr Cor one
Bike mit 2×7 Schaltung passt das auf Wahoo Kickr One ?
The bike frame must allow axle width of 130mm or 135mm. Some old bikes only have 126mm width.
If the 7 speed chain is too wide for the Cog on the trainer, you may need to replace it with an 8 speed chain
OK. But it doesn’t matter that it now has 2×7 sprockets? Maybe a different chain needs to be put on. Correct
No it doesn’t matter as long as the frame fits the trainer and the chain fits the Cog.
Thank you
