Virtual shift with rouvy
Good morning, I’m using the Zwift Ride with Rouvy. I noticed that on downhill routes, even using the 24 gear ratio, the trainer doesn’t get hard enough to make watts in Z3-4-5. Is there a setting that can be changed? I use Elite Direct XR + Cog.
Zwift don’t support the use of the zwift ride on rouvy that is rouvy support you need to ask
Hi everyone,
Thanks so much for posting in the forums! I’m Alejandra from Zwift.
Really appreciate your help @Rhino-Racing and thanks a lot, @FROL92 for sharing your setup and questions with us. It’s great to have you both here!
Based on our Zwift Ride FAQ, the Zwift Ride is designed to work with Zwift to activate virtual shifting. If you’re using it with Rouvy, that feature may not function as expected.
Feel free to let us know if anything else that we can assist you or contact to our support we will be happy to assist you.
Have a nice day all.
