I have been using Zwift for about 3 years.
Before starting zwift academy 2022 I corrected my weight from 77 to 78Kg. Certainly I will have made a mistake by entering an incorrect value, but I realized it after half of the races.
I finish always last (normally in the first 20% of cyclists) and only noticed at the end that zwift always show 0.8 or 1.0 Watt/kg.
I’m 181cm tall and weigh 78kg.
I went to check the weight and it was 7800 kg.
The program shouldn’t accept similar values, or at least the runner shouldn’t move if producing 200/300 watts with a similar weight.
Thanks and sorry for my english.
Too bad you had that:disappointed_relieved: 7800kg it’s a bit overweight…
If you have a smart scale you can connect it to send your weight to Zwift directly so you don’t need to enter it manually anymore…
