I have been on zwift now a few years and always used Bluetooth to connect Tacx Flux however with the amount of drops outs recently and nearly throwing trainer through door, i though i may try ANT has any one any ideas how you can use ANT with a Samsung Tablet as it has no USB ports ???
Not unless it is builtin…Ant+ requires a receiver chip just like BT.
Note that unless your tablet is a Galaxy, it probably is not strong enough run Zwift.
How does it charge with no USB ports? Do the new ones have wireless charging?
What did you use prior to the Tablet?
Hi use usb to normal mobile cable via junc box to tv on samsung tabs6 works fine uses battery quickly when using tv though
