Update problem or not?
Hi, I would like to know if my problem could be related to recent updates. For a couple of weeks now, at the beginning or during a ride, the connection between zwfit ride and Apple TV has been lost. The other Zwifters disappear and then the meetup ends. Using Bluetooth, you can continue to go and save your route. The resistance works. Using companion instead, everything is disconnected and the watts go to zero. I haven’t had this problem doing the workouts on a Windows computer. On Apple TV I uninstalled and reinstalled the zwfit app. I checked that the zwfit ride hardware was up to date. The wifi seems to be ok to me. Should I just wait or is there something I can do? Thank youuuuu
This sounds more like a WiFi problem in your home. When riders disappear, that is most often a network problem (anywhere between your Apple TV and Zwift). When you pair via Companion and it sets up OK but then disconnects, that is almost certainly a problem with your home network since that traffic does not leave your home. So this all points to a probable home network issue.
If the other Zwifters are disappearing, that seems like a pretty good indication that you are losing connection to the internet. Not necessarily a WiFi issue, but internet. Have you tried rebooting your modem and router?
