Update Failed during patching. Error Code Z117 at Line 329 in Patcher.cpp
I already deleted the Zwift folder and re-installed - worked fine first startup, updated, then this came back. Shows up sometimes, Zwift runs fine other times.
Windows 11, i5-9400, 16GB RAM, GTX 1660Ti
There’s a support page for Z117. Does any of that advice help?
( :backhand_index_pointing_up: @John_Zwift)
@Craig_D_Mart, do you have Background Updating or Auto-Startup enabled for Zwift/Zwift Launcher on your PC? If you select the ^ icon near the right edge of your Windows taskbar, you should be able to view hidden icons. From there, you can right-click the Zwift Icon and see if either function is enabled- indicated by a checkmark. Please feel free to confirm they are disabled and let us know how your next few sessions go.
No Zwift icon in the taskbar.
Zwift is running fine, I’m just worried that this is indicating something that will become a problem for a future update that gets pushed when I only have a couple minutes before a race.
Still got the error message this morning. Or at least, I got an error message, not sure if it was the same one, I only had a couple of minutes before my ladder race at 0630.
I have the same error. I uninstalled and reinstalled Zwift, same error appears. Everything seems to run fine though.
