Microsoft.NET Framework - Unhandled exception error when existing Zwift
Could not load type ‘System.ComponentModel’ from assembly?
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.TypeLoadException: Could not load type ‘System.ComponentModel’ from assembly ‘System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’.
at ZwiftLauncher.MainWindow.CleanupTrayIcon()
at ZwiftLauncher.MainWindow.ContextMenu_Exit(Object sender, EventArgs e)
at System.Windows.Forms.MenuItem.OnClick(EventArgs e)
at System.Windows.Forms.MenuItem.MenuItemData.Execute()
at System.Windows.Forms.Command.Invoke()
at System.Windows.Forms.Command.DispatchID(Int32 id)
at System.Windows.Forms.NotifyIcon.WndProc(Message& msg)
at System.Windows.Forms.NotifyIcon.NotifyIconNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5485 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
ZwiftLauncher
Assembly Version: 1.0.0.0
Win32 Version: n/a
CodeBase: file:///C:/Program%20Files/Zwift/ZwiftLauncher.exe
PresentationFramework
Assembly Version: 3.0.0.0
Win32 Version: 3.0.6920.5453 built by: Win7SP1GDR
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
PresentationCore
CodeBase: file:///C:/Windows/assembly/GAC_32/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Runtime.Remoting
Win32 Version: 2.0.50727.5488 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
PresentationFramework.Aero
Win32 Version: 3.0.6920.4902 built by: NetFXw7
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework.Aero/3.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.ServiceProcess
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.ServiceProcess/2.0.0.0__b03f5f7f11d50a3a/System.ServiceProcess.dll
UIAutomationProvider
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/UIAutomationProvider/3.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
Microsoft.mshtml
Assembly Version: 7.0.3300.0
Win32 Version: 7.0.3300.0
CodeBase: file:///C:/Windows/assembly/GAC/Microsoft.mshtml/7.0.3300.0__b03f5f7f11d50a3a/Microsoft.mshtml.dll
System.Web
CodeBase: file:///C:/Windows/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging=“true” />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
