Unachieved Sprint Badges
After finishing The Über Pretzel someone wrote a PM to me, when crossing the AdZ banner backwards I was awarded three Sprint- / Poweroutput Badges. The PM could be incidental. But: No question that I did not achieve these Badges. Not today…
… please reroll these badges (but keep the Über Pretzel, it was so f hard :smile: )
Activity: The at Home Cycling & Running Virtual Training App (zwift.com)
You are probably best to raise a support ticket to request such. Not sure you will get them to action based off this forum post.
Thanks @Gordon_Rhino-Racing for your reply! Basically you’re right. But there might be a bug or even a reproduceable cheat. Maybe some additional information: Used hardware is - besides HR and Zwift Play (via Companion) Elite Justo on ANT+ on PC (Win10). Snippet from the logs, the time between Crossing AdZ Finish forward [22:15:18] and reverse which unlocked:
[22:15:18] Got Notable Moment: ACHIEVEMENT UNLOCKED!
[22:15:18] Requesting Notable Moment Screenshot, type=ACHIEVEMENT UNLOCKED!, delay=1.00, distance=-1.00
[22:15:18] FE-C 17 received
[22:15:18] ANT  : Transfer Completed.
[22:15:18] ANT  : FET grade set successfully
[22:15:19] [INFO] Sending telemetry...
[22:15:19] FE-C 17 received
[22:15:19] FE-C SIM GRADE -0.000
[22:15:19] ANT  : Transfer Completed.
[22:15:19] ANT  : FET grade set successfully
[22:15:19] [GAME]: Saving auto triggered screenshot to server
[22:15:19] [GAME]: GAME_TakeScreenshot(): 1920x1080, Content 0
[22:15:19] [GAME]: GAME_TakeScreenshot(): 1920x1080, Content 1
[22:15:20] [INFO] Sending telemetry...
[22:15:20] [GAME]: Enqueuing screenshots for upload
[22:15:20] FE-C SIM GRADE 0.000
[22:15:20] ANT  : Rx Fail on channel 1
[22:15:20] ANT  : Transfer Completed.
[22:15:20] ANT  : FET grade set successfully
[22:15:21] ANT  : Rx Fail on channel 2
[22:15:21] FE-C SIM GRADE 0.001
[22:15:21] [ActionBarV2] ZCActionBar: UserAction has changed: navigation:coffee_stop (enabled=false)
[22:15:21] ANT  : Transfer Completed.
[22:15:21] ANT  : FET grade set successfully
[22:15:22] FE-C SIM GRADE 0.001
[22:15:22] ANT  : Transfer Completed.
[22:15:22] ANT  : FET grade set successfully
[22:15:22] FE-C 17 received
[22:15:23] FE-C 17 received
[22:15:23] ANT  : dID 1118125 SW Revision 2303 SerialNum 4013
[22:15:23] FE-C SIM GRADE 0.001
[22:15:23] ANT  : Transfer Completed.
[22:15:23] ANT  : FET grade set successfully
[22:15:24] [INFO] Sending telemetry...
[22:15:24] FPS 55.35, -405825, 218589, -689355
[22:15:24] FE-C SIM GRADE 0.000
[22:15:24] ANT  : Transfer Completed.
[22:15:24] ANT  : FET grade set successfully
[22:15:25] [ActionBarV2] ZCActionBar: UserAction has changed: navigation:coffee_stop (enabled=true)
[22:15:25] ANT  : Rx Fail on channel 2
[22:15:25] FE-C SIM GRADE -0.000
[22:15:25] ANT  : Transfer Completed.
[22:15:25] ANT  : FET grade set successfully
[22:15:26] [INFO] Sending telemetry...
[22:15:26] FE-C SIM GRADE -0.000
[22:15:26] ANT  : Transfer Completed.
[22:15:26] ANT  : FET grade set successfully
[22:15:27] FE-C 17 received
[22:15:27] FE-C SIM GRADE 0.000
[22:15:27] ANT  : Transfer Completed.
[22:15:27] ANT  : FET grade set successfully
[22:15:27] [INFO] UDP metrics {StC Rx: 532, Rx error: 0, CtS Tx: 300, Tx error: 0}
[22:15:28] [INFO] Sending telemetry...
[22:15:28] ANT  : Rx Fail on channel 1
[22:15:28] FE-C SIM GRADE 0.000
[22:15:28] ANT  : Transfer Completed.
[22:15:28] ANT  : FET grade set successfully
[22:15:28] Starting critical power curve search job (24184081)  mTimeStamp = 22838.54102  m_lastSearchTime = 22828.52930   calculating=false
[22:15:29] ANT  : Rx Fail on channel 1
[22:15:29] FE-C SIM GRADE -0.000
[22:15:38] ANT  : Rx Fail on channel 2
[22:15:38] FE-C SIM GRADE -0.000
[22:15:38] ANT  : Transfer Completed.
[22:15:38] ANT  : FET grade set successfully
[22:15:38] Starting critical power curve search job (24194030)  mTimeStamp = 22848.59961  m_lastSearchTime = 22838.59375   calculating=false
[22:15:39] FE-C SIM GRADE 0.000
[22:15:42] ANT  : Transfer Completed.
[22:15:42] ANT  : FET grade set successfully
[22:15:43] [ActionBarV2] ZCActionBar: UserAction has changed: teleport:pacers (children=true)
[22:15:43] [ActionBarV2] ZCActionBar: UserAction has changed: teleport:friends (children=true)
[22:15:43] ANT  : Rx Fail on channel 1
[22:15:43] FE-C SIM GRADE -0.000
[22:15:43] ANT  : Transfer Completed.
[22:15:43] ANT  : FET grade set successfully
[22:15:43] ANT  : Rx Fail on channel 2
[22:15:44] [INFO] Sending telemetry...
[22:15:44] ANT  : Rx Fail on channel 1
[22:15:44] FE-C SIM GRADE 0.000
[22:15:47] ANT  : Transfer Completed.
[22:15:47] ANT  : FET grade set successfully
[22:15:48] FPS 57.92, -414347, 218592, -692763
[22:15:48] FE-C SIM GRADE 0.000
[22:15:48] Starting critical power curve search job (24203983)  mTimeStamp = 22858.67383  m_lastSearchTime = 22848.67383   calculating=false
[22:15:48] ANT  : Transfer Completed.
[22:15:48] ANT  : FET grade set successfully
[22:15:49] [ActionBarV2] ZCActionBar: UserAction has changed: navigation:coffee_stop (enabled=false)
[22:15:49] ANT  : Rx Fail on channel 2
[22:15:49] FE-C SIM GRADE -0.000
[22:15:49] ANT  : Transfer Completed.
[22:15:49] ANT  : FET grade set successfully
[22:15:50] FE-C SIM GRADE 0.000
[22:15:50] ANT  : Transfer Completed.
[22:15:50] ANT  : FET grade set successfully
[22:15:51] FE-C 17 received
[22:15:51] FE-C SIM GRADE -0.000
[22:15:51] ANT  : Transfer Completed.
[22:15:51] ANT  : FET grade set successfully
[22:15:52] FE-C SIM GRADE -0.000
[22:15:52] ANT  : Transfer Completed.
[22:15:52] ANT  : FET grade set successfully
[22:15:53] ANT  : Rx Fail on channel 1
[22:15:53] FE-C SIM GRADE -0.000
[22:15:53] Ride on received
[22:15:53] HUD_Notify: C.Ryan (TBR/JETT)  sagt Ride On!
[22:15:53] Got Notable Moment: RIDE ON!
[22:15:53] Play Haptic RECIEVED_RIDEON
[22:15:53] ANT  : Transfer Completed.
[22:15:53] ANT  : FET grade set successfully
[22:15:54] FE-C SIM GRADE 0.000
[22:15:54] ANT  : Rx Fail on channel 1
[22:15:55] ANT  : Rx Fail on channel 2
[22:15:55] ANT  : Transfer Completed.
[22:15:55] ANT  : FET grade set successfully
[22:15:55] Total Ride Ons Given: 354
[22:15:55] Play Haptic RETURN_RIDEON
[22:15:55] FE-C 17 received
[22:15:55] FE-C SIM GRADE -0.000
[22:15:56] [INFO] Sending telemetry...
[22:15:56] ANT  : Rx Fail on channel 2
[22:15:56] FPS 55.35, -418935, 218591, -691675
[22:15:56] ANT  : Rx Fail on channel 1
[22:15:56] FE-C SIM GRADE -0.000
[22:15:56] ANT  : Transfer Completed.
[22:15:56] ANT  : FET grade set successfully
[22:15:57] FE-C SIM GRADE -0.000
[22:15:57] ANT  : Transfer Completed.
[22:15:57] ANT  : FET grade set successfully
[22:15:58] FE-C SIM GRADE 0.000
[22:15:58] Starting critical power curve search job (24214058)  mTimeStamp = 22868.73828  m_lastSearchTime = 22858.72656   calculating=false
[22:15:58] ANT  : Transfer Completed.
[22:15:58] ANT  : FET grade set successfully
[22:15:59] [ActionBarV2] ZCActionBar: UserAction has changed: navigation:coffee_stop (enabled=true)
[22:15:59] FE-C 17 received
[22:15:59] FE-C SIM GRADE -0.000
[22:15:59] ANT  : Transfer Completed.
[22:15:59] ANT  : FET grade set successfully
[22:16:00] ANT  : dID 1118125 SW Revision 2303 SerialNum 4013
[22:16:00] ANT  : Rx Fail on channel 1
[22:16:00] FE-C SIM GRADE 0.000
[22:16:08] FE-C 17 received
[22:16:08] Starting critical power curve search job (24224089)  mTimeStamp = 22878.81055  m_lastSearchTime = 22868.79492   calculating=false
[22:16:08] FE-C SIM GRADE 0.000
[22:16:08] ANT  : Rx Fail on channel 2
[22:16:09] ANT  : Transfer Completed.
[22:16:09] ANT  : FET grade set successfully
[22:16:09] FE-C SIM GRADE 0.000
[22:16:10] FE-C SIM GRADE -0.000
[22:16:10] ANT  : Transfer Completed.
[22:16:10] ANT  : FET grade set successfully
[22:16:11] ANT  : Rx Fail on channel 1
[22:16:11] FE-C SIM GRADE -0.000
[22:16:11] ANT  : Transfer Completed.
[22:16:11] ANT  : FET grade set successfully
[22:16:12] FE-C 17 received
[22:16:12] FPS 57.92, -428550, 218592, -693150
[22:16:12] ANT  : Rx Fail on channel 2
[22:16:12] FE-C SIM GRADE -0.000
[22:16:12] ANT  : Transfer Completed.
[22:16:12] ANT  : FET grade set successfully
[22:16:13] [ActionBarV2] ZCActionBar: UserAction has changed: teleport:pacers (children=true)
[22:16:13] [ActionBarV2] ZCActionBar: UserAction has changed: teleport:friends (children=true)
[22:16:13] [ActionBarV2] ZCActionBar: UserAction has changed: navigation:coffee_stop (enabled=false)
[22:16:13] FE-C SIM GRADE 0.000
[22:16:13] ANT  : Transfer Completed.
[22:16:13] ANT  : FET grade set successfully
[22:16:14] [INFO] Sending telemetry...
[22:16:14] ANT  : Rx Fail on channel 2
[22:16:14] FE-C SIM GRADE 0.000
[22:16:14] ANT  : Transfer Completed.
[22:16:14] ANT  : FET grade set successfully
[22:16:15] [INFO] Sending telemetry...
[22:16:15] ANT  : Rx Fail on channel 1
[22:16:15] FE-C SIM GRADE -0.000
[22:16:15] ANT  : Transfer Completed.
[22:16:15] ANT  : FET grade set successfully
[22:16:16] FE-C 17 received
[22:16:16] FE-C SIM GRADE 0.000
[22:16:17] [INFO] Sending telemetry...
[22:16:17] ANT  : dID 1118125 MFG 86 Model 34
[22:16:17] ANT  : Transfer Completed.
[22:16:17] ANT  : FET grade set successfully
[22:16:17] FE-C SIM GRADE 0.000
[22:16:18] ANT  : Transfer Completed.
[22:16:18] ANT  : FET grade set successfully
[22:16:18] Starting critical power curve search job (24234028)  mTimeStamp = 22888.89453  m_lastSearchTime = 22878.88281   calculating=false
[22:16:18] FE-C SIM GRADE -0.000
[22:16:19] ANT  : Transfer Completed.
[22:16:19] ANT  : FET grade set successfully
[22:16:19] FE-C SIM GRADE -0.000
[22:16:20] ANT  : Transfer Completed.
[22:16:20] ANT  : FET grade set successfully
[22:16:20] ANT  : Rx Fail on channel 1
[22:16:20] FPS 59.29, -433436, 218591, -693447
[22:16:20] FE-C SIM GRADE -0.000
[22:16:21] FE-C 17 received
[22:16:21] ANT  : Transfer Completed.
[22:16:21] ANT  : FET grade set successfully
[22:16:21] ANT  : Rx Fail on channel 1
[22:16:21] FE-C SIM GRADE 0.000
[22:16:22] [INFO] Sending telemetry...
[22:16:22] ANT  : Transfer Completed.
[22:16:22] ANT  : FET grade set successfully
[22:16:23] FE-C SIM GRADE -0.000
[22:16:23] ANT  : Rx Fail on channel 1
[22:16:23] ANT  : Transfer Completed.
[22:16:23] ANT  : FET grade set successfully
[22:16:24] FE-C SIM GRADE -0.000
[22:16:24] ANT  : Transfer Completed.
[22:16:24] ANT  : FET grade set successfully
[22:16:25] FE-C SIM GRADE 0.000
[22:16:25] ANT  : Transfer Completed.
[22:16:25] ANT  : FET grade set successfully
[22:16:25] Chat: Ryan (TBR/JETT)  185957 (Private): GL if everesting. You got this!
[22:16:25] FE-C 17 received
[22:16:26] FE-C SIM GRADE -0.000
[22:16:26] ANT  : Rx Fail on channel 1
[22:16:26] ANT  : Transfer Completed.
[22:16:26] ANT  : FET grade set successfully
[22:16:27] [INFO] Sending telemetry...
[22:16:27] FE-C SIM GRADE 0.000
[22:16:27] ANT  : Rx Fail on channel 2
[22:16:27] ANT  : Transfer Completed.
[22:16:27] ANT  : FET grade set successfully
[22:16:27] [INFO] UDP metrics {StC Rx: 515, Rx error: 0, CtS Tx: 300, Tx error: 0}
[22:16:27] [ActionBarV2] ZCActionBar: UserAction has changed: navigation:coffee_stop (enabled=true)
[22:16:28] [INFO] Sending telemetry...
[22:16:28] FE-C SIM GRADE -0.000
[22:16:28] ANT  : Rx Fail on channel 1
[22:16:28] ANT  : Transfer Completed.
[22:16:28] ANT  : FET grade set successfully
[22:16:28] FPS 54.95, -436365, 218591, -697097
[22:16:28] Starting critical power curve search job (24244088)  mTimeStamp = 22898.98047  m_lastSearchTime = 22888.96484   calculating=false
[22:16:38] FE-C 17 received
[22:16:38] Starting critical power curve search job (24254219)  mTimeStamp = 22909.05273  m_lastSearchTime = 22899.03711   calculating=false
[22:16:39] FE-C SIM GRADE 0.000
[22:16:39] ANT  : Transfer Completed.
[22:16:39] ANT  : FET grade set successfully
[22:16:39] ANT  : Rx Fail on channel 2
[22:16:40] FE-C SIM GRADE -0.000
[22:16:40] ANT  : Transfer Completed.
[22:16:40] ANT  : FET grade set successfully
[22:16:41] FE-C SIM GRADE 0.000
[22:16:41] ANT  : Transfer Completed.
[22:16:41] ANT  : FET grade set successfully
[22:16:42] FE-C SIM GRADE 0.000
[22:16:42] ANT  : Rx Fail on channel 1
[22:16:42] ANT  : Transfer Completed.
[22:16:42] ANT  : FET grade set successfully
[22:16:42] FE-C 17 received
[22:16:43] FE-C SIM GRADE 0.000
[22:16:43] FE-C 17 received
[22:16:43] ANT  : Transfer Completed.
[22:16:43] ANT  : FET grade set successfully
[22:16:43] [ActionBarV2] ZCActionBar: UserAction has changed: teleport:pacers (children=true)
[22:16:43] [ActionBarV2] ZCActionBar: UserAction has changed: teleport:friends (children=true)
[22:16:44] [INFO] Sending telemetry...
[22:16:44] FE-C SIM GRADE -0.000
[22:16:44] ANT  : Transfer Completed.
[22:16:44] ANT  : FET grade set successfully
[22:16:48] Starting critical power curve search job (24264209)  mTimeStamp = 22919.12891  m_lastSearchTime = 22909.12500   calculating=false
[22:16:49] FE-C SIM GRADE 0.000
[22:16:49] ANT  : Transfer Completed.
[22:16:49] ANT  : FET grade set successfully
[22:16:50] FE-C SIM GRADE -0.000
[22:16:50] ANT  : Transfer Failed.
[22:16:50] ANT  : ----------------------
[22:16:50] ANT  : FET Transmission failed. m_CurrentMode = 4
[22:16:51] [INFO] Sending telemetry...
[22:16:51] FE-C 17 received
[22:16:51] FE-C SIM GRADE -0.000
[22:16:51] ANT  : Transfer Completed.
[22:16:51] ANT  : FET grade set successfully
[22:16:51] ANT  : dID 1118125 MFG 86 Model 34
[22:16:52] FE-C SIM GRADE -0.000
[22:16:52] ANT  : Transfer Completed.
[22:16:52] ANT  : FET grade set successfully
[22:16:52] FPS 58.59, -430112, 218591, -707774
[22:16:53] [INFO] Sending telemetry...
[22:16:53] FE-C SIM GRADE 0.000
[22:16:53] ANT  : Rx Fail on channel 2
[22:16:53] ANT  : Transfer Completed.
[22:16:53] ANT  : FET grade set successfully
[22:16:53] ANT  : Rx Fail on channel 1
[22:16:54] FE-C SIM GRADE -0.000
[22:16:54] ANT  : Transfer Completed.
[22:16:54] ANT  : FET grade set successfully
[22:16:55] FE-C SIM GRADE -0.000
[22:16:55] ANT  : Transfer Completed.
[22:16:55] ANT  : FET grade set successfully
[22:16:55] [ActionBarV2] ZCActionBar: UserAction has changed: navigation:coffee_stop (enabled=false)
[22:16:55] FE-C 17 received
[22:16:56] FE-C 17 received
[22:16:56] FE-C SIM GRADE -0.000
[22:16:56] ANT  : Transfer Completed.
[22:16:56] ANT  : FET grade set successfully
[22:16:56] ANT  : Rx Fail on channel 1
[22:16:57] FE-C SIM GRADE -0.000
[22:16:57] ANT  : Transfer Completed.
[22:16:57] ANT  : FET grade set successfully
[22:16:58] FE-C SIM GRADE 0.000
[22:16:58] ANT  : Transfer Failed.
[22:16:58] ANT  : ----------------------
[22:16:58] ANT  : FET Transmission failed. m_CurrentMode = 4
[22:16:58] Starting critical power curve search job (24274153)  mTimeStamp = 22929.20312  m_lastSearchTime = 22919.19922   calculating=false
[22:16:58] ANT  : Rx Fail on channel 1
[22:16:59] ANT  : Rx Fail on channel 2
[22:16:59] FE-C SIM GRADE -0.000
[22:16:59] ANT  : Transfer Completed.
[22:16:59] ANT  : FET grade set successfully
[22:16:59] FE-C 17 received
[22:17:00] [INFO] Sending telemetry...
[22:17:00] FE-C 17 received
[22:17:00] FE-C SIM GRADE 0.000
[22:17:00] ANT  : Transfer Completed.
[22:17:00] ANT  : FET grade set successfully
[22:17:00] FPS 57.36, -427389, 218590, -711137
[22:17:01] FE-C SIM GRADE 0.000
[22:17:01] ANT  : Transfer Failed.
[22:17:01] ANT  : ----------------------
[22:17:01] ANT  : FET Transmission failed. m_CurrentMode = 4
[22:17:02] FE-C SIM GRADE 0.000
[22:17:02] ANT  : Transfer Completed.
[22:17:02] ANT  : FET grade set successfully
[22:17:03] FE-C SIM GRADE 0.000
[22:17:03] ANT  : Transfer Completed.
[22:17:03] ANT  : FET grade set successfully
[22:17:03] FE-C 17 received
[22:17:04] ANT  : Rx Fail on channel 1
[22:17:04] FE-C SIM GRADE 0.000
[22:17:04] ANT  : Transfer Completed.
[22:17:04] ANT  : FET grade set successfully
[22:17:04] ANT  : Rx Fail on channel 2
[22:17:05] FE-C SIM GRADE -0.000
[22:17:05] ANT  : Transfer Failed.
[22:17:05] ANT  : ----------------------
[22:17:05] ANT  : FET Transmission failed. m_CurrentMode = 4
[22:17:06] FE-C SIM GRADE -0.000
[22:17:06] ANT  : Transfer Failed.
[22:17:06] ANT  : ----------------------
[22:17:06] ANT  : FET Transmission failed. m_CurrentMode = 4
[22:17:07] FE-C SIM GRADE 0.000
[22:17:07] ANT  : Transfer Failed.
[22:17:07] ANT  : ----------------------
[22:17:07] ANT  : FET Transmission failed. m_CurrentMode = 4
[22:17:07] FE-C 17 received
[22:17:08] FE-C 17 received
[22:17:08] FE-C SIM GRADE 0.000
[22:17:08] ANT  : dID 1118125 SW Revision 2303 SerialNum 4013
[22:17:08] ANT  : Transfer Completed.
[22:17:08] ANT  : FET grade set successfully
[22:17:08] FPS 56.39, -423402, 218591, -712888
[22:17:08] Starting critical power curve search job (24284207)  mTimeStamp = 22939.28125  m_lastSearchTime = 22929.27539   calculating=false
[22:17:09] FE-C SIM GRADE 0.000
[22:17:09] ANT  : Transfer Completed.
[22:17:09] ANT  : FET grade set successfully
[22:17:10] [INFO] Sending telemetry...
[22:17:10] FE-C SIM GRADE -0.000
[22:17:10] ANT  : Transfer Failed.
[22:17:10] ANT  : ----------------------
[22:17:10] ANT  : FET Transmission failed. m_CurrentMode = 4
[22:17:11] FE-C SIM GRADE 0.000
[22:17:11] ANT  : Transfer Failed.
[22:17:11] ANT  : ----------------------
[22:17:11] ANT  : FET Transmission failed. m_CurrentMode = 4
[22:17:11] Switch By MustTurnRoadTime. Route Decision: Merging onto new road 43 from old road 43, Current Road Time: 0.2793939, Current Direction FORWARD
[22:17:12] [ActionBarV2] ZCActionBar: UserAction has changed: navigation:u_turn (presentable=false)
[22:17:12] FE-C SIM GRADE 0.000
[22:17:12] FE-C 17 received
[22:17:12] ANT  : Transfer Failed.
[22:17:12] ANT  : ----------------------
[22:17:12] ANT  : FET Transmission failed. m_CurrentMode = 4
[22:17:12] ANT  : Rx Fail on channel 1
[22:17:13] ANT  : Rx Fail on channel 1
[22:17:13] FE-C SIM GRADE 0.000
[22:17:13] [ActionBarV2] ZCActionBar: UserAction has changed: teleport:pacers (children=true)
[22:17:13] [ActionBarV2] ZCActionBar: UserAction has changed: teleport:friends (children=true)
[22:17:13] ANT  : Transfer Failed.
[22:17:13] ANT  : ----------------------
[22:17:13] ANT  : FET Transmission failed. m_CurrentMode = 4
[22:17:14] [INFO] Sending telemetry...
[22:17:14] FE-C SIM GRADE 0.000
[22:17:14] ANT  : Transfer Failed.
[22:17:14] ANT  : ----------------------
[22:17:14] ANT  : FET Transmission failed. m_CurrentMode = 4
[22:17:15] ANT  : Rx Fail on channel 1
[22:17:15] FE-C SIM GRADE 0.000
[22:17:15] ANT  : Transfer Failed.
[22:17:15] ANT  : ----------------------
[22:17:15] ANT  : FET Transmission failed. m_CurrentMode = 4
[22:17:16] ANT  : Rx Fail on channel 2
[22:17:16] FE-C SIM GRADE 0.000
[22:17:16] FPS 60.00, -419208, 218591, -714049
[22:17:16] ANT  : Transfer Failed.
[22:17:16] ANT  : ----------------------
[22:17:16] ANT  : FET Transmission failed. m_CurrentMode = 4
[22:17:16] FE-C 17 received
[22:17:17] FE-C 17 received
[22:17:17] FE-C SIM GRADE 0.000
[22:17:17] ANT  : Transfer Failed.
[22:17:17] ANT  : ----------------------
[22:17:17] ANT  : FET Transmission failed. m_CurrentMode = 4
[22:17:17] ANT  : Rx Fail on channel 1
[22:17:17] ===========================================================
[22:17:17] [ActiveSegments] detected state change...
[22:17:17] Removed segment: 2233445522
[22:17:17] ==Current Active Segment Hash Ids==
[22:17:18] ANT  : Rx Fail on channel 2
[22:17:18] FE-C SIM GRADE 0.000
[22:17:18] ANT  : Rx Fail on channel 1
[22:17:18] ANT  : Transfer Failed.
[22:17:18] ANT  : ----------------------
[22:17:18] ANT  : FET Transmission failed. m_CurrentMode = 4
[22:17:18] Starting critical power curve search job (24294216)  mTimeStamp = 22949.35742  m_lastSearchTime = 22939.35156   calculating=false
[22:17:19] FE-C SIM GRADE 0.000
[22:17:19] ANT  : Transfer Failed.
[22:17:19] ANT  : ----------------------
[22:17:19] ANT  : FET Transmission failed. m_CurrentMode = 4
[22:17:20] FE-C SIM GRADE 0.000
[22:17:20] ANT  : Rx Fail on channel 2
[22:17:20] ANT  : Transfer Failed.
[22:17:20] ANT  : ----------------------
[22:17:20] ANT  : FET Transmission failed. m_CurrentMode = 4
[22:17:20] FE-C 17 received
[22:17:21] FE-C 17 received
[22:17:21] FE-C SIM GRADE 0.000
[22:17:21] ANT  : Rx Fail on channel 1
[22:17:21] ANT  : Transfer Completed.
[22:17:21] ANT  : FET grade set successfully
[22:17:22] [INFO] Sending telemetry...
[22:17:22] FE-C SIM GRADE 0.000
[22:17:22] ANT  : Transfer Failed.
[22:17:22] ANT  : ----------------------
[22:17:22] ANT  : FET Transmission failed. m_CurrentMode = 4
[22:17:23] ANT  : Rx Fail on channel 2
[22:17:23] FE-C SIM GRADE 0.000
[22:17:23] ANT  : Transfer Completed.
[22:17:23] ANT  : FET grade set successfully
[22:17:23] ANT  : Rx Fail on channel 1
[22:17:24] FE-C SIM GRADE 0.000
[22:17:24] FPS 60.12, -414991, 218591, -713359
[22:17:24] ANT  : Transfer Completed.
[22:17:24] ANT  : FET grade set successfully
[22:17:25] FE-C 17 received
[22:17:25] FE-C SIM GRADE 0.000
[22:17:25] ANT  : dID 1118125 MFG 86 Model 34
[22:17:25] ANT  : Transfer Completed.
[22:17:25] ANT  : FET grade set successfully
[22:17:25] ANT  : Rx Fail on channel 1
[22:17:26] ANT  : dID 1118125 MFG 86 Model 34
[22:17:26] FE-C SIM GRADE 0.000
[22:17:26] ANT  : Transfer Completed.
[22:17:26] ANT  : FET grade set successfully
[22:17:27] FE-C SIM GRADE 0.000
[22:17:27] ANT  : Transfer Completed.
[22:17:27] ANT  : FET grade set successfully
[22:17:27] [INFO] UDP metrics {StC Rx: 411, Rx error: 0, CtS Tx: 300, Tx error: 0}
[22:17:28] [INFO] Sending telemetry...
[22:17:28] ANT  : Rx Fail on channel 2
[22:17:28] FE-C SIM GRADE 0.000
[22:17:28] ANT  : Transfer Completed.
[22:17:28] ANT  : FET grade set successfully
[22:17:28] Starting critical power curve search job (24304233)  mTimeStamp = 22959.42578  m_lastSearchTime = 22949.42578   calculating=false
[22:17:29] [INFO] Sending telemetry...
[22:17:29] FE-C SIM GRADE 0.000
[22:17:29] ANT  : Transfer Completed.
[22:17:29] ANT  : FET grade set successfully
[22:17:38] FE-C SIM GRADE 0.000
[22:17:38] FE-C 17 received
[22:17:38] ANT  : Transfer Failed.
[22:17:38] ANT  : ----------------------
[22:17:38] ANT  : FET Transmission failed. m_CurrentMode = 4
[22:17:38] Starting critical power curve search job (24314228)  mTimeStamp = 22969.50195  m_lastSearchTime = 22959.49609   calculating=false
[22:17:39] FE-C SIM GRADE 0.000
[22:17:39] ANT  : Transfer Failed.
[22:17:39] ANT  : ----------------------
[22:17:39] ANT  : FET Transmission failed. m_CurrentMode = 4
[22:17:40] ANT  : Rx Fail on channel 1
[22:17:40] FPS 59.64, -410283, 218592, -706446
[22:17:40] FE-C SIM GRADE 0.000
[22:17:40] ANT  : Rx Fail on channel 2
[22:17:40] ANT  : Transfer Completed.
[22:17:40] ANT  : FET grade set successfully
[22:17:41] FE-C SIM GRADE 0.000
[22:17:41] ANT  : Transfer Completed.
[22:17:41] ANT  : FET grade set successfully
[22:17:42] FE-C 17 received
[22:17:42] FE-C SIM GRADE 0.000
[22:17:42] ANT  : dID 1118125 SW Revision 2303 SerialNum 4013
[22:17:42] ANT  : Transfer Completed.
[22:17:42] ANT  : FET grade set successfully
[22:17:43] ANT  : dID 1118125 SW Revision 2303 SerialNum 4013
[22:17:43] [ActionBarV2] ZCActionBar: UserAction has changed: teleport:pacers (children=true)
[22:17:43] [ActionBarV2] ZCActionBar: UserAction has changed: teleport:friends (children=true)
[22:17:43] FE-C SIM GRADE 0.000
[22:17:43] ANT  : Transfer Completed.
[22:17:43] ANT  : FET grade set successfully
[22:17:48] Starting critical power curve search job (24324224)  mTimeStamp = 22979.57812  m_lastSearchTime = 22969.57031   calculating=false
[22:17:49] FE-C SIM GRADE 0.000
[22:17:49] ANT  : Transfer Completed.
[22:17:49] ANT  : FET grade set successfully
[22:17:50] [INFO] Sending telemetry...
[22:17:50] FE-C SIM GRADE 0.000
[22:17:50] ANT  : Rx Fail on channel 2
[22:17:50] FE-C 17 received
[22:17:50] ANT  : Transfer Completed.
[22:17:50] ANT  : FET grade set successfully
[22:17:57] ANT  : Rx Fail on channel 2
[22:17:57] FE-C SIM GRADE 0.000
[22:17:57] ANT  : Transfer Failed.
[22:17:57] ANT  : ----------------------
[22:17:57] ANT  : FET Transmission failed. m_CurrentMode = 4
[22:17:58] [INFO] Sending telemetry...
[22:17:58] ANT  : Rx Fail on channel 2
[22:17:58] FE-C SIM GRADE 0.000
[22:17:58] ANT  : Rx Fail on channel 1
[22:17:58] Starting critical power curve search job (24334234)  mTimeStamp = 22989.66406  m_lastSearchTime = 22979.64844   calculating=false
[22:17:59] FE-C 17 received
[22:17:59] ANT  : Transfer Completed.
[22:17:59] ANT  : FET grade set successfully
[22:18:07] ANT  : Rx Fail on channel 1
[22:18:07] FE-C 17 received
[22:18:07] FE-C SIM GRADE -0.000
[22:18:08] FE-C 17 received
[22:18:08] ANT  : Transfer Failed.
[22:18:08] ANT  : ----------------------
[22:18:08] ANT  : FET Transmission failed. m_CurrentMode = 4
[22:18:08] FE-C SIM GRADE -0.000
[22:18:08] Starting critical power curve search job (24344214)  mTimeStamp = 22999.74414  m_lastSearchTime = 22989.73438   calculating=false
[22:18:09] ANT  : Transfer Completed.
[22:18:09] ANT  : FET grade set successfully
[22:18:09] ANT  : Rx Fail on channel 1
[22:18:09] FE-C SIM GRADE -0.000
[22:18:10] ANT  : Transfer Completed.
[22:18:10] ANT  : FET grade set successfully
[22:18:10] ANT  : Rx Fail on channel 2
[22:18:10] ANT  : Rx Fail on channel 1
[22:18:10] FE-C SIM GRADE -0.000
[22:18:11] ANT  : Transfer Completed.
[22:18:11] ANT  : FET grade set successfully
[22:18:11] FE-C SIM GRADE -0.000
[22:18:12] FE-C 17 received
[22:18:12] ANT  : Transfer Completed.
[22:18:12] ANT  : FET grade set successfully
[22:18:12] FPS 58.82, -406301, 218587, -690114
[22:18:12] ANT  : Rx Fail on channel 1
[22:18:12] FE-C SIM GRADE -0.000
[22:18:13] ANT  : Rx Fail on channel 1
[22:18:13] [ActionBarV2] ZCActionBar: UserAction has changed: teleport:pacers (children=true)
[22:18:13] [ActionBarV2] ZCActionBar: UserAction has changed: teleport:friends (children=true)
[22:18:13] ANT  : Transfer Completed.
[22:18:13] ANT  : FET grade set successfully
[22:18:14] FE-C SIM GRADE -0.000
[22:18:14] [INFO] Sending telemetry...
[22:18:14] ANT  : Transfer Completed.
[22:18:14] ANT  : FET grade set successfully
[22:18:15] FE-C SIM GRADE -0.000
[22:18:15] ANT  : Transfer Completed.
[22:18:15] ANT  : FET grade set successfully
[22:18:16] ANT  : Rx Fail on channel 2
[22:18:16] FE-C SIM GRADE -0.000
[22:18:16] FE-C 17 received
[22:18:16] ANT  : Transfer Completed.
[22:18:16] ANT  : FET grade set successfully
[22:18:16] ANT  : dID 1118125 SW Revision 2303 SerialNum 4013
[22:18:17] FE-C SIM GRADE -0.000
[22:18:17] ANT  : Transfer Completed.
[22:18:17] ANT  : FET grade set successfully
[22:18:18] FE-C SIM GRADE 0.000
[22:18:18] ANT  : Transfer Completed.
[22:18:18] ANT  : FET grade set successfully
[22:18:18] FE-C Cal status = 0   temp=0  spd=1 target speed = 20.7
[22:18:18] Starting critical power curve search job (24354204)  mTimeStamp = 23009.82812  m_lastSearchTime = 22999.81445   calculating=false
[22:18:19] FE-C SIM GRADE 0.001
[22:18:19] FE-C Cal status = 0   temp=0  spd=1 target speed = 20.7
[22:18:19] ANT  : Transfer Completed.
[22:18:19] ANT  : FET grade set successfully
[22:18:19] ANT  : Rx Fail on channel 1
[22:18:20] FE-C SIM GRADE 0.001
[22:18:20] ANT  : Transfer Completed.
[22:18:20] ANT  : FET grade set successfully
[22:18:20] FPS 60.85, -409192, 218590, -688713
[22:18:21] FE-C SIM GRADE 0.001
[22:18:21] ANT  : Transfer Completed.
[22:18:21] ANT  : FET grade set successfully
[22:18:21] FE-C 17 received
[22:18:22] FE-C SIM GRADE 0.002
[22:18:22] FE-C 17 received
[22:18:22] ANT  : Transfer Completed.
[22:18:22] ANT  : FET grade set successfully
[22:18:22] ANT  : Rx Fail on channel 2
[22:18:23] FE-C SIM GRADE 0.017
[22:18:23] Got Notable Moment: ACHIEVEMENT UNLOCKED!
[22:18:23] Requesting Notable Moment Screenshot, type=ACHIEVEMENT UNLOCKED!, delay=1.00, distance=-1.00
[22:18:23] ANT  : Transfer Completed.
[22:18:23] ANT  : FET grade set successfully
[22:18:23] Switch By MustTurnRoadTime. Route Decision: Merging onto new road 46 from old road 46, Current Road Time: 0.9682452, Current Direction REVERSE
[22:18:23] LIVESEG: Sending Active Segments.
[22:18:23] TimingArch: hit finish line for Alpe du Zwift
[22:18:23] [ActionBarV2] ZCActionBar: UserAction has changed: navigation:u_turn (presentable=true)
[22:18:24] FE-C SIM GRADE 0.022
[22:18:24] [INFO] Sending telemetry...
[22:18:24] ANT  : Rx Fail on channel 2
[22:18:24] [GAME]: Saving auto triggered screenshot to server
[22:18:24] ANT  : Transfer Completed.
[22:18:24] ANT  : FET grade set successfully
[22:18:24] [GAME]: GAME_TakeScreenshot(): 1920x1080, Content 0
[22:18:24] [GAME]: GAME_TakeScreenshot(): 1920x1080, Content 1
[22:18:24] [GAME]: Enqueuing screenshots for upload
[22:18:25] [INFO] Sending telemetry...
[22:18:25] FE-C SIM GRADE 0.005
[22:18:25] ANT  : Transfer Completed.
[22:18:25] ANT  : FET grade set successfully
[22:18:25] FE-C 17 received
[22:18:26] [INFO] Sending telemetry...
[22:18:26] FE-C SIM GRADE 0.004
[22:18:26] FE-C 17 received
[22:18:26] ANT  : Transfer Completed.
[22:18:26] ANT  : FET grade set successfully
[22:18:27] [INFO] Sending telemetry...
[22:18:27] FE-C SIM GRADE 0.002
[22:18:27] ANT  : Transfer Completed.
[22:18:27] ANT  : FET grade set successfully
[22:18:27] [INFO] UDP metrics {StC Rx: 491, Rx error: 0, CtS Tx: 300, Tx error: 0}
[22:18:28] [INFO] Sending telemetry...
[22:18:28] FE-C SIM GRADE 0.001
[22:18:28] ANT  : Transfer Completed.
[22:18:28] ANT  : FET grade set successfully
[22:18:28] ANT  : Rx Fail on channel 2
[22:18:28] FPS 55.56, -416294, 218638, -686937
[22:18:28] Requesting Notable Moment Screenshot, type=ACHIEVEMENT UNLOCKED!, delay=1.00, distance=-1.00
[22:18:28] Starting critical power curve search job (24364243)  mTimeStamp = 23019.89844  m_lastSearchTime = 23009.89648   calculating=false
[22:18:29] FE-C SIM GRADE 0.005
[22:18:29] ANT  : Transfer Completed.
[22:18:29] ANT  : FET grade set successfully
[22:18:29] ANT  : Rx Fail on channel 1
Upload that log file to zwiftalizer.com if you want to see any problems with the trainer connection
Hi everyone, welcome to Forums. Thanks for all your suggestions. This is Juan from Zwift. @Michael_Muller9, the best way to address this is to open a support ticket. Attaching the activity link was a well-thought-out idea, there we can verify that you got the achievement banner.
Additionally, we can take a look in detail at your account to figure out what happened. Please feel free to contact us, we will be delighted to help.
