I used mirroring on iphone to LG 4k Tv, then I start zwift on iphone that is projected on TV.
About one third of the time, TV just shuts itself off, presumably from overheating. Should I buy apple tv to resolve this issue. Also is zwift a video game and if so, should i use the gaming picture mode to resolve this issue.
If your LG is shutting off from overheating, it would shut off also for other things. Itâs a good brand and I guess you donât have a low range model. No need to buy an Apple TV just for that.
I have the same issue with a TV attached to a PC. After 4 hours the TV will power off. It can be made to stay on by changing a setting in the âEcoâ mode of the TV
Some kind of power save mode either on the TV or the phone would indeed be the most plausible explanation. The TV itself is not doing anything more demanding than showing video, so forget about overheating.
My guess is that the TV is just turning itself off due to âinactivityâ after some period of time. i.e. you are not changing the channel, or adjusting the volume, or any other sort of interaction. I have had this happen in the middle of something I was watching, as I had not âinteractedâ with the TV in a while. I think it just presumes you are gone, and forgot to turn it off. So, if itâs always turning off at around the same time after you start Zwifting you might look for some sort of âauto-offâ setting on the TV to see if it can be changed, or perhaps just adjust the volume every so often using the remote, so that it knows youâre âstill thereâ.
Is your iPhone ok with this? Just checking itâs not your iPhone overheating and stopping mirroring, and the TV turns off through lack of an input. I would have thought youâd have noticed that, but just thought Iâd put it out there.
Iâve used wireless screen-mirroring extensively and my experience is itâs generally flaky and tends to disconnect.
I switched to a hard-wired connection using Appleâs Lightning Digital AV Adaptor and that worked better. Ultimately, I went AppleTV and PC, again, hard-wired.
I am using a 43" TV for Zwift via connection with a CPU which does not shut off anytime as long as Zwift is running. The TV will shut off only when the CPU has inactivity according to the set timing to do so.
