When I try and do the welcome ride , as it’s loading Watopia it crashes and closes the app down
Any ideas as I need to know what all the symbols mean
Thanks Jim
Thanks Jim
What device are you running Zwift on? It’s not a laptop with a Snapdragon processor, is it?
Hi Steve
I’m using iPad running ios17.7.10
Is it quite an old iPad? There’s a known crashing problem on 2GB iPads which is fixed in Zwift 1.100.
Hi again Steve
It’s a 6th Gen iPad
It says I’m running gave version 1.99.0
Ok, well that looks to be a 2GB model, and so there’s a good chance that your problem is fixed in 1.100.
Unfortunately there’s no way to speed up the roll-out (but do check the App Store). But if you don’t have the update available to you now, you should get it in the next couple of days.
Hi @Jim_Bratt
Shuji at Zwift HQ here. I peeked at your server logs and see indications of crash, followed more recently by rides that appear to have completed normally ( a ~12 mile ride on Ocean Lava Cliffside Loop).
When you crashed - did you choose a route in Watopia, or was it one of the guest worlds? Do you recall? Some worlds are more memory-hungry than others, and low-RAM devices can run into issues.
