Trouble Connecting Wahoo
Hi, after update the last version from the App, I had difficulties to connect the wahoo… after several attempts I succeeded and 35 min in the middle of my work out the app disconnects again from de devise, I couldn’t finished my workout :face_holding_back_tears:
Which model of Wahoo trainer do you have? What type of device are you running the game on? Which method did you use to pair the trainer to the game?
Hi Paul, thanks for your reply!
My Wahoo is KickCore I just bought it recently in December , I am running the game on Apple 15 Pro, and I pair the the trainer to the game through Bluetooth.
Today I try to finish the same workout starting from zero, unluckily it was disconnected almost at the same time :sob:
I will wait for your kind support, I don’t want to miss my training plan
Thank you
Your pairing screen shows that you are connecting the trainer via WiFi and not Bluetooth. I would test it with Bluetooth instead. It is not unusual to have better connection stability when using Bluetooth instead of WiFi with that trainer. Let me know if that helps or not.
(Thank you for posting that screenshot, it helps a lot.)
Sorry I did not finish looking at all the pictures. It looks like the heart rate monitor is also having problems. I suspect that is a different problem, which is that the Apple Watch does not work reliably with Zwift. To solve that problem, I recommend getting a normal heart rate monitor. You could also try using an app like HeartCast to make it broadcast your heart rate more like a normal heart rate monitor, but the easiest solution is to get either a chest strap or optical arm band heart rate monitor.
To followup @Paul_Southworth , use the App “HeartCast” on the Apple Watch. Takes a few seconds to start but it works reliably (for me) when I need it.
I wonder if there is any problem with running the HeartCast app on the same phone that runs Zwift. I have not tested that. Do you know if it works?
I have not tested. I think you can start HC directly from the watch. If not, the phone seems secondary to the watch…but in the end I do not know how it works…if the phone is doing the broadcast or the watch? Some testing to do. If I remember.
Update: I just started the app on the watch. Have to see if it will connect to Zwift.
