Tourmalet showing spring classic segments
Hi
I climbed (ok survived) the Tourmalet climb but on Strava it’s also reporting a PB on the Paterburg climb, and a 2nd for the Koppenburg descent ?!
That sounds sort of similar to this report
possibly the wrong segments have been put on strava as I had the same thing with the shorter climbs with strava saying the same segment despite different cliombs
It is a Strava issue, not Zwift. It is caused by Zwift overlapping portal climbs on the map. (Your Zwift records are accurate.)
This issue is over a year ago. The shorter climbs are straight. A sharp curve will not overlap a straight segment. Try riding Norton, same issue. The real rides get over-taken. Your Tourmalet/Patterberg segment probably has a different amount of altitude than the real Patterberg.
Found more explanation from Eric who manages the Strava segments
