Test FTP
Bonjour,
J’ai fait un test FTP et j’aimerais savoir où je peux trouver le résultat du test.
If you go into Zwift, select your profile image, and go into “My Profile” (not sure what this is called in French), then you will see what your current FTP is set to in the “FTP” box on your profile page. You can also change it here.
Normally you should see the FTP show up on screen after your FTP test if you do the ramp test, or the 20min FTP test in Zwift.
Also, if you select any workout in the game, before you select “Start Ride” you will see a line on the bottom right hand corner that represents your FTP as well.
Merci, j’ai trouvé.
Thanks, I found it.
