As I know it has HDMI , surely there is no ANT+ firmware ( really rare and depending on Android version too ! ) however you can solve using an USB ANT+ dongle.
From some week I started to use Teclast also for running using a Treadmill plus a Zwift runpod (Bluetooth). It works very well also for this purpouse.
Merci Gwenal_Digne & Grazie Graziano
I just ordered on French âCdiscountâ web site this Tab.
Hope everything will be good and at the end I can Zwift Also !!
good night, i ordered a t30 keyboard after your feedback, i would like to know if you can tell me if i can pedal for about 7 hours straight without needing to connect the charger? is the battery really good?
If you donât mind, you can install ANT Tester from Google play. If the device has a build in ANT+ then the green tick would display there. From there just need to download the driver without needing the dongle
