TDZ stages
Beginner here
If I take a route change on the TDZ how do I get back onto the route? Just done stage 3 Scotland and not been awarded it despite doing the distance but map showed there was a section I didn’t do and part I did twice!
What am I doing wrong?
Are you choosing the routes from the home screen or are you.joining an event?
You shouldn’t need to make any manual turns, just ride until the route is finished.
Looks like you did the full route?
But what’s that note about your laptop died? Did you have to start over?
It is fairly common that riders with steering devices accidentally turn off the route, which I believe you did after only two circuits of the Breakaway Brae Reverse loop when three need to be completed.
Check your screenshots and you will notice you were still on route after 33 minutes but had left the route before 49 minutes.
If your steering device is quite sensitive you might wish to change your Intersection Control to disabled in Settings.
Picking route from home screen
Laptop died after a couple of minutes so started again. Used that time as a warm up!
So if I choose to change route when it gives you the option I ignore it?
Yeah, dont do any route changes.
Fab thanks for the help everyone.
I’m still a very newbie Zwifter but loving it!!
