The frame rate is a very low and steady 20FPS, which is a bit odd. Is the laptop plugged in to power and are you using Zwift’s Laptop Battery Saver setting?
The level of crowding (avatars close to you during the activity) is not particularly bad.
There are no Bluetooth dropouts shown in the report.
There is one TCP disconnect at the end of the activity which could be a network problem. There are signs of very poor network latency, like packets taking half a second to make a round trip. That is not good. Even a network connection from India to the US should perform better than that.
You are pairing some things via Companion and some things directly to the Mac so you do have the option to either pair everything through Companion or everything directly to the Mac. That gives you a couple ways to test different pairing configurations. If network problems are involved in this situation, pairing everything via Bluetooth directly to the Mac would eliminate the possibility that the network problem would affect pairing via Companion which bridges the connection via WiFi.
Hi Paul, firstly thank you so much for the assistance it is much appreciated. So yes I was running on battery my next ride I recorded I was on power. I did a ride on Saturday and had 2 drop outs one at 10m:46s into the ride and a second long one (15-20 seconds) at the 36 minutes 12 seconds mark. Again this is where I lose all power and the flywheel just spins. I rode yesterday again and this time I reset my router and all wifi devices and I did not experience any problem at all. Which may speak to the network as being a potential issue. Below is Saturday’s ride
In this one, everything is paired via Bluetooth, nothing bridged through Companion, so network problems won’t have any effect on pairing. Frame rate is solid (as expected with that hardware) until the end. Everything appears to go merrily along, no sign of any disconnections from the trainer at the times you mention losing resistance, until at the end of the ride you got two Bluetooth disconnects and a TCP network error and two brief crashes of the frame rate all pretty much at the same time.
So when you lost resistance, Zwift never noticed the trainer going away. Zwift thought everything was fine at those times.
And at the end of the ride, all I can surmise is that something happened on the laptop that had a very negative effect on system performance because the frame rate cratered briefly around the same time that other bad things happened. But that event doesn’t line up with when you noticed resistance going away.
Hallo all. I just want to mention that I was comforting finding this post, to see I’m not alone in this. Last year a spend countless hours trying to figure out what is wrong with my expensive trainer, tried it all, external cadence/steel extension garmin send me replacement 2t, problem still exist when climbing using virtual shifting ( and to make matters worse i also have a taxc alpine, which excagarrtes the problem when going on steep hills somehow). So frustrating that garmin does not solve this.
In the end I ended up reinstalling my derailleurs instead of the zwift cog and whenever I need to race the only solution is physical gears.
If anyone ever finds the real solution I’ll keep an eye on this post
Hey everyone,
I’m using a Tacx NEO 2T with Virtual Shifting too (Zwift Cog & Click) and Trainer Difficulty set to 30%. Does increasing Trainer Difficulty to 50% fix this virtual shifting bug? Did someone try this?
Greetings
I’ve tried this and still having the same
Issue. Just did a full out sprint and same resistance drop at the end.
What’s really crazy is I’ve complained to Garmin about this issue ever since I got zwift ride and they converted into virtual shifting and every time they just send me a new trainer when I’ve told them I don’t think it’s the trainers issue. So frustrating.
