Switched to Zwift Cog, Lost the Quiet KICKR
I got tired of the bulky Zwift Play controllers and bought the Zwift Click instead. It works great! It also came with the Zwift Cog, so I installed it with my 12 speed SRAM chain and derailleur. However, it’s considerably noisier than running an 11 speed Shimano cog on the KICKR (without shifting). And yes, I spent a considerable amount of time fine tuning everything.
Anyone else notice the same difference in noise?
Yes, Zwift cog is noisy, the plastic discs amplify the noise. I used a single cog from an old cassette & these spacers. You could probably use them with the cog that’s in the 'Zwift Cog", it’s easy to remove.
@Peter_Hi I always thought the concept of micro adjusting the cog position without having to adjust the dereur was genius, but the noise is a real drawback. Anyway, I appreciate your feedback. At least I’m not going crazy! :joy: Last night, I bit the bullet and switched back to a standard cassette, but I like your hack much better!
I set up the COG three days ago. It’s incredibly loud. If I had used a 1S chain, maybe it would have been quieter. But I don’t want to try that anymore. I went back to my old cassette, and now it’s quiet.
Yeah, a bit disappointed because I really wanted to like it. However, I’m willing to spend money to make my setup quieter and more efficient, not the other way around.
Great that you got your click running. Mine arent working at all. And yeah just by pedaling a bit i realised the coq is loud. All in all absolute shitty investment
@Max_Heldmann Mine only started working after I updated the app for some reason; I’m using Zwift on a PC, which usually works well with ANT+, but not! with Bluetooth for the trainer and HRM. With the Zwift Play/Click, I was fortunate that everything works smoothly, despite my initial concerns (they are bluetooth).
Hi thanks for your advise, but i already Updated everything i could. Zwift deinstall and new install on the PC with Update. Update of the companion App, Update of the click and Update of the kickr. Nothing worked.
Today i am getting new clicks delivered. Maybe that helps
@Max_Heldmann Are you using Windows by any chance? Regardless of what some people might say, my experience has been that Windows, Zwift, and Bluetooth aren’t fully compatible. It’s hit or miss. It works perfectly for some people, while others constantly struggle. There must be thousands of discussions about this over the years.
I can never get Zwift to run with my Kickr’s, my HRM’s, or even Runn over Bluetooth. Meanwhile, ANT+ and direct Wi-Fi connections are absolutely flawless.
When I got the Zwift Play, I tested it immediately with the intention of returning it if it didn’t work properly. Fortunately, it worked. That’s why I suspect my Zwift Click paired without issues after the update.
At the end of the day, it’s all about that damn Bluetooth connection.
Yeah its windows. The new clicks arrived and they pair with the Computer but Zwift Always loses them and never finds them again. Via Companion the garmin hrm doesnt Work even in the unsafe Connection Mode.
And the best thing is if i leave the App (still Open in the Background) all Connection is lost! Also if the lockscreen sets in everything gets lost. And in the half hour i was riding IT even lost a few times Connection for 1-2 Seconds with the App on.
Currently i am done with the click & ■■■■ and also with Zwift. All my Bluetooth works Just fine like Headphones, Garmin devices etc. But Zwift seems to be to dumb to get it solved
Not sure how well my setup matches yours, but I use Windows 11 with everything paired via Bluetooth every day and have approximately zero problems. I do not use the Bluetooth adapter built into the PC - instead I use an Edimax BT-8500 which has the same chipset as a TP-Link UB500 (the latter is quite a popular dongle for people who use Zwift). It’s on a 2m USB extension cable that came with an ANT+ adapter I used to use. In my system I disconnected the USB header from the internal Bluetooth adapter so to Windows it does not exist, but you can also disable a built-in Bluetooth adapter in Device Manager, or sometimes in the system BIOS. I’m pairing a Kickr Core (v1) and Zwift Ride controls and sometimes a Coospo or Garmin HRM if I’m racing. This is very trouble free for me.
Loads of people have laptops or desktops with crap Bluetooth reliability in Zwift, and it’s quite common to see better results with a dongle like the TP-Link UB500. Success rate is not 100% but overall quite good. My observation is that systems using Bluetooth 4.x are especially at risk, but I have seen recent new good quality PCs with Bluetooth that was inadequate to the task and was fixed with a dongle.
@Paul_Southworth The problem is exclusively with Zwift, Windows, and Bluetooth, not the adapter. I ran TrainerRoad, Rouvy, and IndieVelo extensively without a single issue.
ANT+ has always worked flawlessly. I switched to direct Wi-Fi for the trainer back in March/April 2021 and wouldn’t go back. However, it’s disappointing that Zwift has never really fixed its Bluetooth issues, especially as ANT+ is gradually being phased out and HRMs rely on either Bluetooth or ANT+.
The Runn also provides better data over Bluetooth, particularly incline readings, but ANT+ remains 100% reliable. I even tried several different Bluetooth cards, including the Intel Wi-Fi 6E AX210 I’m currently using (which was one of the most recent models at the time). You’d think that would be more than enough to reliably connect a basic HRM. My biggest frustration with the problem is that Zwift’s official response is deflection rather than actually fixing the issue!
I even went so far as to install a Bluetooth antenna right above me for better signal! LOL
Oh i can relate to the frustration.
This is working very well for me, bt 5.4 LMP 13, win11 pc. Stable, works, easy. Good luck!
Hi Max, using kickerCore2 cogs, and after the last update nothing worked, turns out I had to manually recalibrate the kickerCore2 ( using and connected only to the wahoo phone app), and after that zwift worked fine.
