Suito and Ekar
Hi everyone.
I’ve tried to find info regarding Suito-T and Ekar compability. Is there a workaround or is the only way to use a 12-speed Campy freehub together with a 12-speed cassette? :expressionless:
Thanks!
Regards
Martin
A 12 speed cassette is not going to work well with 13-speed Ekar. It won’t shift properly and the chain won’t fit the 12 speed cog properly.
I believe Tacx is the only trainer manufacturer that supports the N3W freehub.
You could probably use it with the Zwift Hub One if you put a 12 speed chain on the bike.
