Stopping at slow speed
At slow speeds on the steepest climbs I completely stop and have to rachet up the power level to get started again. Anyone know how I can fix this?
I’d assume this is a problem that will “fix itself” as you get fitter. An alternative might be to reduce the “trainer difficulty” slider so you’re effectively in a lower gear. In turn that should increase your cadence and that might help the game recognise that you’re still moving.
If it’s just that Zwift “stops” you if you go below, say 2kph, then there’s little you can do other than get stronger I think.
I would also recommend that you stick to the most flat routes until you build your fitness.
Thanks for the advice folks.
