I haven’t used the companion app for weeks. Thank you for implementing Windows BLE compatibility. I was happy to find pairing solutions which no longer required the companion app as a man in the middle device. Here’s the thing though, when looking at my logs weeks later, Zwift is still looking for my phone every 30 seconds. The perpetual searching and failing to connect is not improving my Zwift Software performance.
Here’s part of my log from today’s ride.
[12:53:12] NETCLIENT:Auxiliary Controller: Attempting to connect to phone at: 192.168.2.11:21587
[12:53:12] FPS 94, 414277, 10529, -102977
[12:53:14] FPS 92, 413536, 10564, -102982
[12:53:15] FPS 93, 412847, 10596, -102993
[12:53:16] FPS 93, 412193, 10626, -102998
[12:53:17] NETCLIENT:WARN: Auxiliary Controller: Error shutting down tcp socket: ‘A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied.’ (-894438672)
[12:53:17] NETCLIENT:ERROR: Auxiliary Controller: Error connecting socket: ‘The I/O operation has been aborted because of either a thread exit or an application request.’ (995)
[12:53:17] FPS 93, 411567, 10654, -103006
[12:53:18] FPS 92, 410974, 10678, -103012
[12:53:19] FPS 92, 410404, 10700, -103019
[12:53:19] NETCLIENT:UDP StC received count: 54001
[12:53:19] NETCLIENT:UDP StC popped count: 54001
[12:53:19] NETWORK:Delayed packet detected: Delay=158.20, Meters=102.9 networkID=53400, rider name=I
[12:53:20] FPS 94, 409865, 10718, -103024
[12:53:21] FPS 97, 409367, 10733, -103039
[12:53:21] Starting critical power curve search job (895330172) mTimeStamp = 2463.12451 m_lastSearchTime = 2463.12451 calculating=false
[12:53:22] FPS 96, 408879, 10745, -103032
[12:53:23] FPS 98, 408370, 10754, -103044
[12:53:24] FPS 100, 407840, 10761, -103047
[12:53:25] NETWORK:Delayed packet detected: Delay=248.55, Meters=104.4 networkID=937512, rider name=P
[12:53:25] NETCLIENT:Sending telemetry…
[12:53:25] FPS 98, 407287, 10764, -103056
[12:53:26] FPS 101, 406718, 10765, -103062
[12:53:27] FPS 102, 406130, 10763, -103070
[12:53:28] NETCLIENT:Auxiliary Controller: Attempting to connect to phone at: 192.168.2.11:21587
12:53:28] NETWORK:Delayed packet detected: Delay=244.80, Meters=115.1 networkID=274620, rider name=J
[12:53:28] FPS 101, 405518, 10757, -103077
[12:53:29] FPS 105, 404900, 10750, -103082
[12:53:30] NETWORK:Delayed packet detected: Delay=421.56, Meters=118.2 networkID=903009, rider name=N
[12:53:30] FPS 102, 404257, 10740, -103082
[12:53:31] FPS 103, 403585, 10729, -103079
[12:53:31] Starting critical power curve search job (895340172) mTimeStamp = 2473.13672 m_lastSearchTime = 2473.13672 calculating=false
[12:53:32] FPS 105, 402901, 10718, -103075
[12:53:33] NETCLIENT:WARN: Auxiliary Controller: Error shutting down tcp socket: ‘A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied.’ (-894438672)
[12:53:33] NETCLIENT:ERROR: Auxiliary Controller: Error connecting socket: ‘The I/O operation has been aborted because of either a thread exit or an application request.’ (995)
[12:53:33] FPS 106, 402210, 10708, -103071
[12:53:34] FPS 107, 401506, 10701, -103067
[12:53:35] FPS 107, 400799, 10697, -103063
[12:53:35] NETWORK:Delayed packet detected: Delay=6.80, Meters=115.8 networkID=948422, rider name=C
[12:53:36] FPS 105, 400078, 10699, -103067
[12:53:36] NETWORK:Delayed packet detected: Delay=251.96, Meters=121.0 networkID=483638, rider name=R
[12:53:36] NETWORK:Delayed packet detected: Delay=13.60, Meters=120.5 networkID=50820, rider name=L
[12:53:37] FPS 106, 399355, 10703, -103082
[12:53:38] FPS 106, 398626, 10708, -103101
[12:53:38] NETWORK:Delayed packet detected: Delay=21.98, Meters=126.3 networkID=436430, rider name=H
[12:53:39] FPS 105, 397899, 10716, -103125
[12:53:40] FPS 103, 397169, 10725, -103150
[12:53:40] NETWORK:Delayed packet detected: Delay=32.30, Meters=128.5 networkID=561100, rider name=M
[12:53:40] FPS 105, 396444, 10735, -103175
[12:53:41] Starting critical power curve search job (895350164) mTimeStamp = 2483.15161 m_lastSearchTime = 2483.15161 calculating=false
[12:53:41] FPS 102, 395733, 10746, -103199
[12:53:42] FPS 102, 395025, 10757, -103224
[12:53:43] NETWORK:Delayed packet detected: Delay=25.32, Meters=122.1 networkID=1045240, rider name=U
[12:53:43] FPS 99, 394318, 10769, -103249
[12:53:44] NETCLIENT:Auxiliary Controller: Attempting to connect to phone at: 192.168.2.11:21587
