I asked Zwift Coach to become a stronger climber and have my doubts about the plan. To understand my doubts, here is some context:
My zftp is 3.15 w/kg. So a high C, I think.
As you can see in the first screenshot I try to put some effort in my training. I don’t spend many hours on the bike so I aim for a lot of yellow in the bar graph.
In the other 2 images you see a part of the plan from Zwift Coach. I feel like it’s simply not good enough to make some progress. Workouts with effort ratings of 2/5 or 3/5 (I’ve tried them in the past and they mostly don’t feel hard) and pacing with Betty (I like to ride with Genie).
Should I stick to the plan and trust the process or ditch it? I don’t want to waste weeks if it doesn’t make me a stronger climber.
If they feel easy, have you done a recent FTP test?
Not zFTP or some other unusual calculations - I mean the old fashioned 20min or 60min all out effort?
Or go hit the Alpe du Zwift and do a flat out attack on that and see what your average power on the climb is, that’s also an okay benchmark.
I think they probably want you to have an easy recovery on that day. But 60 minutes seems a bit short.
My day today it wants me to do 210 minutes with Jacques group - which I won’t because it’s just not on my own plan for the year. I interpret it to do what I’d planned on my own, but at a moderate pace - and I’ll do about 2 hours.
I haven’t done a test recently. Somewhere in the summer my FTP auto-adjusted after a hard 20 minute effort. Other hard efforts - without an official test - didn’t change it the last couple of months.
I think you’re right about the ride with Betty. It looks like a recovery ride but it is short… and another problem is that you’ll hit lower numbers because of the draft. For example: I can stay an hour with Genie with an average of 3.1 w/kg, even though Genie is listed as 3.7 w/kg. So that ride with Betty will probably be way less intensive than the Zwift Coach “thinks”, which makes it a wrong choice in my opinion.
That’s exactly my thoughts - the robopacer rides aren’t all that good for this purpose, if you are great at drafting, you can get along with lower power output than intended.
In this case substitute something else comparable or go use a TT frame.
You may be ready for another FTP test, or even just use the ramp test if you don’t want to do a full 20min flat out. Rest up ahead of it, be fueled up properly - follow whatever warmup protocol works for you.
The prescribed erg workouts look fine, it’s just a matter of how they feel in RPE (rate of perceived exertion), if they feel easy then the FTP needs to be a bit higher.
But it’s also important that the FTP isn’t so high that you cannot complete the workouts. They should be hard, but able to complete them - completion is important. If you are missing blocks of a workout because it’s so hard, then you aren’t getting the right training load and you won’t be getting the benefit, so then you’ll dial the FTP down a bit.
Hi @Fiets - If you check out Fitness Trends screen > Training Score you’ll see the projected lift in CTL (Chronic Training Load) which is essentially your fitness. The dotted line here shows that by following the plan, you will increase accordingly. Its only a 4 week plan you have selected so your gains will be limited. But it does appear to be a well balance plan with intensity and rest days based on your selected availability.
I see you have a few routes matched. Make sure to review the Coach pre-ride notes on those days to ensure you get the most out of the session.
is this supposed to be true for anyone with a current plan using Coach? When I look at my fitness trends it only shows the past, not the future, no dotted line.
I’m not sure if you are sticking with a Plan or are playing with Remove It and start again. If you are happy to Remove could you try setting your weekly goal to SP, updating or saving and then set up a new Plan.
Does the new plan revert you to hours as your weekly goal with now no means to change anywhere.
There’s no dotted line visible, but I’m not the only one as you can see in the replies. It’s a solid line that stops at the current date.
However, thanks for the reply. I’ll try it, starting this weekend
One final point of feedback: you’re saying basically that the gains will not be significant because I set the period to 4 weeks. As a user I could expect/desire an extra high intensity because of the short period I’ve selected, to make the gains more significant. However, that’s not how the coach works if I’m understanding you correctly.
Would you go into the gym and do 2 hour long full body workouts 6 days a week and expect good results? Probably not, right? You’d be cooked before the first Friday.
Same thing applies with endurance training, unless you want to crash and burn very quickly. It’s not in your - or Zwift’s - interests for that to happen.
