This bug doesn’t only affect Stages but also both my Kickr v5 and Elite Nero and this bug has persisted for at least1 year (or my entire time on Zwift! )
Btw I was wrong about ANT, it’s a Bluetooth only bug
My Saris H3 has always been this way. First connect as source, then resistance, and then go back and connect either my P1 pedals or QUARQ as the source. I picked up the Saris in 2020. I think my Kickr Snap before then was the same.
And it’s not a technical requirement because in eg Rouvy it’s not necessary to do that.
Incidentally it seems Zwift is completely unaware of this as even this week support suggested
Unplug the Nero from the wall. On the Zwift pairing screen, first pair your power meter and confirm you see power. Then plug the Nero back in and pair it only as Controllable.
Use Zwift Companion as a bridge: Open the Zwift Companion app on your phone (connected to the same Wi-Fi as your PC). On the pairing screen on your computer, click the gear icon and select “Use Zwift Companion” to handle Bluetooth through your phone.
In Windows, also ensure your network is set to Private (not Public).
If nothing pairs, on the pairing screen, click the Speed Sensor tile first and let Zwift find the trainer. Then go back and pair your power meter as Power and the trainer as Controllable.
