Sportstech F37 (FitShow console): incline never returns to 0% in Zwift, so elevation keeps climbing
On my Sportstech F37, any incline change makes Zwift keep about 1% after I return the treadmill to 0%, so the activity keeps gaining elevation on a flat treadmill.
I logged the treadmill’s Bluetooth FTMS data alongside Zwift and found the cause. At 0% the console doesn’t send an incline of 0. It leaves the Inclination field out of the Treadmill Data packet altogether (the flags drop that bit). Above 0% it sends the value normally. Going down to 0 always passes through 1%, so the last incline Zwift receives is 1%, and Zwift keeps it.
Evidence from one run (0 → 2 → 8 → 0 → 4 → 0%):
  • Treadmill log: the Inclination field is present at 1–8%, and missing in every packet at 0%.
  • Zwift FIT: during each 0% stretch the altitude still rises by about 1% of the distance: [X m over Y m] and [X m over Y m].
The Sportstech app does show 0%, so the console knows it’s at 0%. Only the FTMS data leaves it out.
Suggestion for Zwift: when a complete Treadmill Data packet (speed present) arrives without the Inclination field, after earlier packets had it, treat the incline as 0% instead of keeping the last value.
