Today I encountered a problem while trying out some sprints. When sprinting in the biggest gear (52x11) I start spinning out. This would never happen to me on the road.
At one point, I was doing 600-700 Watts at almost 120 RPM in the biggest gear. Does anybody else have this problem? Would love to hear some possible solutions.
Thanks in advance!
I’m using an Elite Suito. Zwift runs on my laptop and the trainer is connected via an ANT+ dongel and I have made sure the ERG mode is turned off. There are no connection problems.
Hi @Floris_Thunnissen, I took a peek at your activities and it looks like you had some trouble with your pairing and the trainer resistance ended up not being paired for this ride. Since you normally pair the controllable portion of your trainer this would create the sensation of spinning out since you’re just turning the flywheel with no added resistance. Next time you ride try making sure that all of your trainer functions pair using the option with FE-C in the name and it should feel like what you’re used to.
