Hi all,
Discussing with colleagues if there would be a significant difference between the front and back wheel when using the bike on rollers.
My setup: Wahoo Speed RPM on front wheel. Set up with correct wheel size (700 x 25c) and unlisted rollers. Wahoo Cadence RPM sensor on non drive side crank.
i.e. could the band linking my Tacx Antares rollers be slipping and therefore my front wheel is not being “driven” as much as my back wheel?
Reason I ask is that there is no way on earth the figures coming out compute with my effort!
I looked on Wahoo’s website and it said place the speed sensor on your preferred wheel but a lot of other sites mention the front wheel. I think the “driven” wheel would give you the most accurate reading?
Your thoughts would be appreciated!
