My setup:
Zwift: Quarq chainring PM/KickrV6 BT/Clckrv2/HRM Strap/PC (i7V7 w/RTX4060)/55" LGTV
Backup: KickrV6 Ant+ to BoltV2 + HRM
Typically I powerup the Bolt once I have picked a ride. Reason being that it used to “fight” with Zwift for priority. I usually have the Kickr read 5-10% below the Quarq (“Zeroed” prior to every ride). Today I powered up the Bolt prior to starting the pairing of Zwift. Zwift still grabbed the correct signals and the Bolt seemed to be fine. I get a message on the Bolt about “Read Only” for the Kickr so all normal.
But the numbers pretty much matched the entire ride (Weekly climb/TOW1 - “Beach…” and a few minutes with Bernie). I have not checked Strava where I send both sets of data to confirm…but it appears to be a much better match.
I need to read up on signal protocol.
