Hello everyone, i’m kinda new to Zwift and borrowed my sisters Wahoo Kickr V5 to have some fun.
I own a Canyon Endurace with a 52/36 chainring and a 11-34 12 speed (i have mounted this 11-34 on the kickr). Now i was doing a group ride on Mountain route with a friend checkmarking “keep group together”. But my buddy is definitely the faster/more powerful rider, so i was chasing almost entire ride. (definitely on the climbs)
From IRL experience the cadence speed chart [website calculator](https://www.bikecalc.com/speed_at_cadence)
is pretty accurate with my rides on the real roads and speeds and on the flats in Zwift also within considerable margin. Now we hit the radio tower part and as you can see i was mostly doing 80-90rpm and between 5 and 8kph. I even maxed at 100RPM at a speed of 7.5kph. But the cadence chart tells me that in my lightest gear (which i remember selecting because i can’t downshift furter i should do a minimum of 10.9kph in that gear on 80RPM and on 100RPM even 13.63kph.
- 36x34 is a gear ratio of 1.06
- 700Cx30mm tire has a circumference of 2180mm, 2180/1000=2.18m
- (2.18x80(rpm)x60)/1.06=9871 meters in 1 hour aka 9.87kph minimum
- Even a 20mm tire would have a circumference of 2120mm what comes to a result of 9.6kph minimum where zwift registered 5-7kph
Is this correct that the speed is 30-50% off of real life or where would this difference be created?
My Weight 59kg and Length 1.80m are correct. The indicated power seems within considerable margin. My FTP was set to 140 and after this 1 hour ride corrected upwards to 147 what all seems fine and pretty accurate. So i’m satisfied and pretty confident with everything registered except the indicated / registered speed.
I could give another example of a somewhat similar ride a couple of days ago on Road to Sky when we didn’t check the ride together function. I recall mostly riding in 1-3 and 1-2 gears… so 36x 27 or 30 cogs on 80RPM pretty constant which would result in 12-14kph but Zwift registered.
Are my speed calculations with the website tool wrong or is it essentially impossible for me to ride with 80-100RPM at these speeds in the lightest gears or maybe the Kickr isn’t translating something right from what is happening? What am i overlooking or what is going wrong? or should i not pay attention to the speed at all?
