Right now, to see how hard a route is, I look at the duration (and it is very unclear whose duration it is, with different numbers shown for the same route). And at what power anyway?
I think the Power Units necessary to complete the route are a much more stable indicator of the effort required.
For instance, the Alpe is about 3.1, so I know that at 1.5 W/Kg, it will take me roughly 2 H.
I know the number is not exactly a constant (some dependency on weight and power), but way more constant the duration, and aligned with some of the challenges.
I mean the routes have the elevation gain and distance, so if you’ve ridden a bunch you’d have a sense of how long that would take no? Power units is a made-up metric in Zwift so I would think fewer folks would know how to convert power units into a timeframe/effort than distance/elevation?
I’m not sure what the time estimate in game is, but for whatever reason it tends to work out relatively close to what I end up doing the routes in, so for me those work pretty well.
I think the dependency on trainer difficulty is minimal (but so it is for duration).
The current metric “duration” depends massively on the power output: 1 W/K, vs 3 W/K.
If I read my estimated time on the Road To Sky = 1H30M, it is nowhere near what I can achieve and I have no idea what power output they have used to generate that number.
The proposal is to displays number which has less (zero would be impossible) dependency on power output, and it is something already being used, for instance by zwift insiders to estimate the time.
Pick Road To Sky again: 4 W/K 55 minutes, 2 W/K 55 minutes. This is more or less 210 Power Unit Minutes which is very clear and concise.
1 number to represent (approximately) the whole zwift insider time estimates.
For what it’s worth, I think Zwift estimates route duration based on 75% of your in-game FTP.
As for Trainer Difficulty, I was thinking it would have more of an impact on hillier routes, because you would still need to put out the same power to get up the hills, but if TD is at zero, you’d also need to pedal down the hills, instead of just coasting. So, more overall power used to complete the route.
