When I’m looking at routes, as well as distance, elevation and time estimate, show the makeup of the surfaces, e.g. 70% road, 30% gravel for a route. I don’t want to have to stop my ride because I’ve chosen the wrong bike.
For what it’s worth, you don’t ’have to’ stop your ride. You can continue on whatever bike you’re already on. Also, once you ride for a bit you’ll know where the different road surfaces are.
Not to say that Zwift couldn’t do what you’re requesting, just that it’s not likely to happen.
the changes to surface Crr a little over a year ago kind of remove the need to switch bikes now anyway.
If you’re interested in a third-party solution to this, use zwiftmap.com to look up the percentage of each surface type. Example:
Thanks Paul!
Will tell you best frame and wheels for all routes except any brand new changes.
