I had been using my Kickr Core to report cadence but I just got the Wahoo RPM cadence sensor. Is there a way to set the RPM sensor as the default instead of having to go into the pair menu and manually select it?
Hi @adiallo, what system do you use to run Zwift? On a PC you can delete the prefs.xml file in documents/zwift. When you restart Zwift it will write a new file and save the paired devices as default. That should take care of this.
I am on Win 10 PC and Zwift always starts with the configuration I used for the last ride, so I think just once disconnect, search and connect the other sensor should work, too.
Thanks, @Mike_Rowe1. I’m running it on iOS through an iPad.
