Hi!
I do a lot of workouts in Zwift and if it consists of multiple sets, then you can’t really see what’s coming in the left screen… because the automatic scroll is very “slow”… it will show mostly the sets that you already finished and not the ones you still have to do… Could the ‘current’ set be more in the middle instead of at the end?
… as an alternative you could use the Companion App where the workout tab will show your progress through the intervals as you go.
I’m a bit confused by your experience. I do almost exclusively workouts in Zwift. My experience is that the highlighted/active interval starts at the top of the list, regardless of how many total intervals are in the workout. The highlighted/active interval then progresses down the list to the bottom, if there are 16, or fewer total intervals. If there are more than 16 intervals, the active/highlighted interval will still start at the top of the list, but once you move from the 8th to the 9th interval, the first interval will move off the top of the list, and the 16th interval will show up at the bottom of the list, followed by the line telling you how many intervals are remaining to be ‘scrolled’ into the list.
Basically, the only time the highlight approaches the bottom of the list is when you are in the last intervals of the workout.
I will try to make a picture of what I mean soon, I realise my explanation is not so clear!
