Hello,
I noticed a small number of posts referencing this bike. The only concern I have is the resistance level, is this similar to a spin bike and would it be suitable for around 45mins just to keep fit?
Thanks.
Hello,
Thanks.
Hi there,
I’m not quite sure what you mean. The Schwinn Classic Cruiser has 7 gears. That is similar to a normal bike with 7 gears. I never use gear 1, because it is to easy. I barely use gear 2, only for warm up and cool down. For my normal riding I use gears 3 to 5. Gear 6 and 7 are for special efforts like sprints. The maximum output in gear 7 is 762 watts. This is what an average rider may sustain for 10 to 20 seconds or so.
Even an unexperienced and unfit rider will be able to ride in gears 1 and 2 and probably even 3 for a long time.
Thomas
Thanks for the information. Where did you find the data about the maximum output in each gear?
I did not find any data anywhere. I experienced that I was not able to ride more than 762 watts in sprints even if I was able to ride with higher cadence, so I wrote to Schwinn customer support and asked. They confirmed that the max output is 762 watts. In lower gears, I suppose that the max output is de facto limited by cadence.
Tom
I picked up the bike, but I find the resistance level quite low unless I am in gear 7. Do you experience the same?
