Hi, my Saris constantly turns the resistance too high where I can’t even pedal.
I believe the calibration is completely off and I can’t figure out how to adjust it.
I constantly reach points where I can’t even pedal unless I stand put my enter weight on a single rotation.
Please advise.
B_Jimmy
(James )
December 23, 2022, 3:47pm
#2
Have you downloaded the Saris app and tried to calibrate it using that? That would be the first step.
Hi @Ilan_Fehler , welcome to the forums.
Are you experiencing this while doing a workout/training plan with ERG mode enabled?
Yes exactly.
I put on one of the Zwift workouts and ride.
And yes I downloaded the app, ran the firmware update.
Road for 10 minutes then calibrated.
Yes exactly doing one of the trainings
I think you are experiencing the “spiral of death”, in ERG mode the trainer will add more resistance if your cadence lowers, so the trick is to keep a high cadence the entire time, 80 or more (unless the workout calls for a low cadence interval, but that probably won’t be less than 60 rpm).
Yes exactly but I can’t hold it as the resistance gets out of wack
You need to keep your cadense up.
Did you do a FTP test are your FTP set correctly.
