Run pod
Hi, can I use the run pod while I use doing skimountaineering?
Thanks?
I don’t see why not but it’s clearly not going to be reflective of the activity you are doing. Not sure if it’s designed to operate at such low temperatures either.
Thanks Stuart. Finally, I tried tu use my Garmin Fenix 6X pro and works fine, but I have a doubt about if I can see dsnv positive in run zwift. Becausez in skimountaineering the most important thing is the positive metres. If I can not used it, I will use only Garmin with Strava and indoor bike in Zwift. (Sorry for my English) thanks :+1::+1::+1:
You can link your Garmin to Zwift using the virtual run mode. It will use your arm movements to predict speed.
I want basically to have and see to positive meters than I do, for exemple 1000m positives.
And I think that in Zwift there is not Challenges about this how for exemple (Everest challenge in bike).
