Road Surface and foliage layers not resting on the ground
There are a number of locations around the island that the tarmac and the foliage do not appear attached to the ground. At its most extreme you can get a view like the attached image (I switched the camera angle to the one that pans across a rider as they go by).
Viewing from the first-person perspective you can tell things are a little off, particularly where a hill drops off quickly after the road; the pavement and the ground will scroll past you at slightly different speeds or a swath of grass will cantilever into the air.
Graphics for the game are really great but I’d get the layers glued together a little tighter for the official launch, if possible.
Hi Aaron,
This is a known bug on our end (that particular angle should not be possible either). We are working on it for sure!
