Ride report: critical power curve colors and labels are swapped
On MacOS, the critical power curve(s) have two different colors, one for best power to date, and one for the current ride. the same colors are used on the tags that float above the cursor to display the watt numbers. However, I have found that when the best and current curves cross each other, the colors used to render the watt tags invert, i.e. the best watts are shown in the current ride curve color, and vice versa. sample images attached
