In regards to ride leader/pacebot distance behind you. It is currently located at the bottom of the screen, right in the middle. Without the power graph enabled it is visible and usable.
However, enable the power graph and it becomes obscured when you go into power output levels above 2.
Would it be possible to relocate between the mini-map and the center infobar (ride distance, elapsed time, etc).
