I have the Cycleops 4870 trainer that’s been working fine until recently. I can get the power connection to work but suddenly the resistance won’t connect to Zwift. I have used Gemini AI to do extensive testing but still no luck. My ANT dongle is on an extension cable and placed right below my trainer. I don’t have any Garmin apps to hijack the connection. I have cleared the previous connections file in my zwift folder. I read this is not a native connection and am wondering if Zwift dropped this in the latest release. Just figured I would try to get help here before upgrading to the wahoo kickr. Ps this is the ANT only version so blue tooth is not an option
I don’t think there’s been any intentional change here. Can’t rule out a bug, of course.
How about if you shut down Zwift and pair it to a cycling computer or Garmin watch? Those things can often execute an ERG mode workout that would establish if it works at all.
If you can afford a more modern trainer I think you would really enjoy that. It’s always more effort to keep the legacy stuff alive.
Another option would be to do a complete re-install of Zwift where you destroy all the settings and start over. All the steps in this document: Reinstalling Zwift
Thanks Paul
I will try a complete reinstall. I don’t have a Garmin or any other apps to connect to. I do agree that after about 10 years of my cycleops it’s probably time to upgrade to the wahoo Kickr Core 2 with wifi connection as I lose too much cycling time trying to get connections going each time.
I did a reinstall and no change the resistance on my trainer is still not connecting. I am now pretty sure this is something on the Zwift software update side. I say this because I reconnected a laptop that I had used previously and everything worked fine but after the older laptop did a zwift software update the same problem occurred with the resistance not connecting.
You should contact support so they can take a look at your game logs.
@Russell_Page_British Welcome to Zwift Forums! Many smart trainers utilize two different ANT+ signals; one that utilizes universal FE-C communication, and usually a secondary signal that only reliably sends power data and is not reliable for resistance communication.
If you navigate to the pairing screen and attempt to manually pair by selecting the Power tile and then the All filter, do you see more than one pairing option for your trainer?
- If you see an option that contains “FE-C,” please select that option (for Power) before pairing to Resistance.
- If you see more than one, but don’t see an FE-C option, I recommend selecting the less generic-sounding option. (e.g. between “CycleOps 4870” and “ANT+ POWERMETER,” select the CycleOps option for Power, then pair to Resistance via the same option)
If this doesn’t clear things up, please feel free to reach out to support for more assistance.
Thanks Rowdy
I have now reached out to support and today purchased a wahoo Kickr core 2 that I am excited to move onto as so much of my training time is always lost trying to get my devices connected.
In my power screen I only get the cyclops power meter show up with the ant icon next to it. Previously once I selected that the resistance meter typically connected at the same time but that stopped happening and now when I click on the resistance button nothing shows up. I used AI to trouble shoot extensively and tried disconnecting power but no luck. My pedals connected over ant for cadence and my trainer connected over Ant for power but for the life of me I cannot connect resistance any longer.
Hopefully things will be much easier over wifi with my Core2
