Resistance drops to zero and takes 20 sec to get right readings when passing from ERG to standard
(Simone Chiaretta) #1
I just did an FTP test and I noticed a problem when the actual FTP testing started, when from ERG mode the control passed to standard mode.
I was around 130W in the interval before the FTP, then the FTP test started, the readings of the power dropped to zero and took 20sec to get back to the actual power I was pushing for the FTP. I guess this happened because from ERG mode the resistance switched to the standard mode and so it took a while for the power meter to get the correct readings.
Maybe you could switch off ERG 10-20 sec before the test starts so that when the it starts there is no wrong reading
