Resistance on the wattbike stays the same as the interval resistance when the recovery is a free ride and theres no set power. This is using a wattbike atom with erg mode on. Means the recovery is just as hard as the interval.
Hope this makes sense. How can I correct it?
Hi Jonathan, the issue appears to be a known issue - I can’t link to the thread but if you search for “Free ride” sections of workouts don’t disengage ERG mode on Wattbike Atom then you should find it.
I raised a ticket yesterday. It would help if everyone who has this experience also raises tickets ![]()
I mean I guess you can just turn ERG mode off temporarily and reduce the resistance by changing gear yourself? But dno if that works on wattbikes :3
Thanks for the reply
Doesn’t seem to switcg off…
RIP
8char
