Race ranking discussion
Stopping using categories for racing will alienate the lower categories.
Result based categorisation is what we want to get to ultimately, but this is a good (and well received) first step.
Thanks. Genuinely no idea why noone suggested it before. Come on Zwift, do as the man suggests.
That is already possible, there is a lot of races that start everyone together, so if that is what you prefer then that is already possible.
I meant something different.
Instead of fixed limits, you just join a race.
And an algorithm puts you based on your Elo-rating (initially based on the “critical power/FTP” and changed by the race results) in a group with similar riders.
The number of groups are based on the registrations.
For example:
99 riders are split into 3 groups (high, normal, low) of 33 riders.
400 riders are split into 5 groups of (very high, high, normal, low, very low) of 80 riders.
It’s more like dynamic categories.
There is a multi-year discussion on what you have proposed. That’s why you were linked to it for “light reading”. You haven’t introduced a new idea to the discussion.
@Manuel_Asberger2870
What you just typed was discussed many times in the Tread the James pointed to. In short that is what Zwift is working towards. Have a read it will give you all the information.
This is step one where we are currently.
.[quote=“James Bailey, post:129, topic:578846, full:true, username:JamesBailey”]
[/quote]
Why do you think so? It didn’t happen on other games. In my opinion dynamic race groups based on previous results encourage weaker riders. Like me :slight_smile:
At the moment you alienate everybody who is just over a cat-limit.
Sorry, but the zwiftpower race-rankings only works for a or b-rider :slight_smile:
Stop using categories? I saw this only once.
Then took it as a reminder that Category enforcement isn’t the answer for the cause.
It’s only a light cure for the sandbaggers (symptom).
Hi @Manuel_Asberger2870
I think the discussion is better suited for this topic. All about ranking.
See e.g. Rankings based matchmaking (get rid of cats!) Give it a vote if you like it.
or just search for “Matchmaking” on the forum.
Yes. I like it. Except the zwiftpower ranking system. In my opinion the Elo-rating is well approved (chess, sports and most of the video games) and better.
But the thread was from December 2020.
I just want to make sure, that the new category enforcement isn’t the answer.
It’s better than nothing. But still not good.
You can start in any cat you want above your minimum - why don’t you do it?
I am not sure you are going to be happy racing against A or A+ riders.
I think you misunderstand. Instead of using categories you’re using splits.
For example, the minimum split size is 40 riders. When 100 riders register for a race you’ll get 2 splits with 50 riders.
The rider with the highest ELO ranking gets bib number 1, etc. That way you know who you’re racing and your predicted result. If you’re #81 in the ELO ranking of those 100 riders, your bib number will be 31, there are 30 riders in your split with a higher ELO ranking.
Now you’ve a race where 120 riders register. In this example you’re also #81 of those 120 riders. 120 riders means 3 splits with 40 riders. Your bib number? 1. You’re the one to beat.
Since it matters who you’re racing when using ELO ranking you’ve always a goal, namely beating those with a lower bib number.
