Race doesnt upload
Hi, has anyone had the following problem, during the race my avg watts etc. were not visible, it is included in zwiftpower, but without any performance figures, then I see the race under my feed on zwift.com but when I click on it it says something went wrong and the page does not open, the race was also not synced with garmin connect, has anyone solved this?
It sounds like the activity did not save properly. There’s nothing you can do to fix it in your Zwift activity feed, but you may be able to upload the fit file from the device you ran the game on to Garmin Connect manually.
These are the instructions if you run Zwift on a PC, Mac, or mobile device:
Assuming you are able to access the fit file, this is a method for adding it to Garmin Connect:
  • Mmm I understand, but the strange thing is that after the race I got a box with performance stats for the race and there were the average numbers, somehow I can't open it in zwift.com, I see it in the summary but have to be able to tap on it to access the gear, because that's probably the only way to download it manually?
