Hi everyone, I have problems when I connect my new Elite Direto XR via PC with ant + USB stick.
In the connections menu, under the controllable item there are two options with ant +: ELITE FEC and ELITE CONTROLLABLE. With both options, the roller is not controlled by zwift and does not automatically adjust the intensity of the resistance, in the power options, on the other hand, ELITE PWR is selected and the power works.
If, on the other hand, I select ELITE XR32 with bluetooth both in controllable and power everything works correctly.
Do others of you have the new Elite XR connected via ant + and is it working properly?
It should work with the fe-c option.
