I can connect and make it work only if I connect via smartphone Companion app. The Bluetooth connection to my PC is just not great and tends to drop in the middle of a ride. I don’t have issues connecting any other devices (elite, Garmin, HRM, Rizer, keyboard all connect fine).. but I am guessing the transmitter on the click is just not robust enough? I upgraded the Bluetooth antenna on my PC but still not keeping connection. fyi the TV and PC are about 5 feet away but PC is behind TV panel .. again though no other issues except for Click.
I have a MTB so Play won’t work.
I thought of the following but not sure what I should get specifically:
use a BT media controller or game controller - how do I do this and what would work best?
get drops to replace my MTB bars and use Play Probably too much work though
get Play and find a way to use it from my bike desk. Or build some kind of mount or mount adapter?
Try a USB Bluetooth dongle on a 2m extension. It doesn’t always fix it, but very often it does, and it doesn’t cost much to try. I’m currently using the Edimax BT-8500 and have used the TP-Link UB400 prior to that. Both work well. I think TP-Link UB500 is the same chipset as the Edimax. The other BT adapter can be disabled in device manager, or perhaps in BIOS.
