Sandy, you’re MVP!! It works now. Pro 2 detected in Bkool Indoor, but cant see any form of Ant+ FE-C option though (see attached image). Tried my luck to check on zwift and it is there now. Thanks a bunch!! Will give it a ride this afternoon. #RideOn.
Javier, allow me to assist you on this. You will have to edit the content of “version.dat”, not renaming it. To do that, follow below steps:
Right-click version.dat, and select Edit to open in text editor - Notepad. (Note: If Notepad is not configured as the default program, you can open it in Notepad by right-click > Open With > Notepad / Choose Another App > Notepad.
In the Notepad, modify the number to 5.14. Save the file and close.
You shall proceed with the rest of the workaround.
Note: I believe your computer system is in Spanish as well. The options mentioned above may vary. Google Translate might helps.
Perfect! I’m just glad to get another person riding in lockdown
muchas gracias. lo he intentado y no sé si de forma exitosa, al intentar guardalo, no me deja pues me dice " no tengo permiso para editarlo, consulte con el propietario del archivo o el administrador"
continuo y ejecuto el programa, me sale una advertencia para que actualice a una versión nueva, le doy a cancelar y me dice que el programa no se iniciará pues no está actualizado.
¿ debo instalar esa nueva versión ?
Hi Javi, don’t install the new version of the Bkool Sim as it won’t let you enable the Ant+ FE-C mode.
If you can’t edit the version.dat file then you may need to try another method which just replaces the file with a new one:
- Open a text editor (e.g. notepad) and in a new file simply write “5.14” (without the quotes)
- Save this new file with the name “version.dat”
- Delete the original “version.dat” file from the Bkool Sim installation directory
- Copy your new file into the above directory
muchísimas gracias. ya lo he realizado todo y con éxito. ahora solo me queda una ultima cuestión, si deseo combinar ambos simuladores, me recomiendas que desinstale el bkool antiguo y me baje el nuevo o continuo con esa versión. no vaya a ser que se desconfigure del nuevo el rodillo.
Excellent news! If you’ve enabled Ant+ FE-C and everything is working in Zwift then you should be fine to update the Bkool sim to the latest version now and use that too.
Hello everybody,
I have got a problem with the ANT connection. On zwift and bkool simulator, when I only use ANT system without bluetooth, my bkool smart pro 2 can’t be controlable by the application (the slope does not change the difficulty of pedaling ) but the others setting are ok ( cadence, power, speed…).
It is not a problem with bkool simulator because I can use the bluetooth but in zwift you must use ANT system for the controlable mode. However I really want to use my bkool smart pro 2 on zwift with an immersive experience.
you can see my setting on zwift with the screenshoot in attachment.
My computer : hp elite book 840
My Home trainer : bkool smart pro 2
Serial number : 32 09 17 73 7C 55 21
I have tried to install the old version like you said on the top, but when I try to find my Home trainer only with the ANT system, my Home trainer isn’t found. But in the same time with zwift my home trainer is found with the ant FEC…
Hi Pierre,
I’ve seen a couple of people with a similar problem to yours but I’m not sure what the solution is yet so it would be good to find one. It looks like you have got Ant+ FE-C enabled since Zwift can see it as a controllable trainer, so you shouldn’t need to go through the steps to do that via the old Bkool Sim.
I just have a few questions:
- How far away is the Bkool from the computer? If you move it nearer does that make it work?
- If you choose to do a workout in Erg mode on Zwift, does it control the resistance of the trainer or not?
- What is your trainer difficulty level set to?
Hello Sandy, thank you for your help during this confinment !
- I think 1m but the distance doesn’t change something.
- I just tried to do a workout with ERG mode and the resistance doesn’t change.
- for this training there is a difference of 123 watts ( top : 250w ; low : 127w).
I did screenshot you can see in attachment.
Thanks Pierre,
For the trainer difficulty what I should done is pointed you to the actual setting: Zwift How-To: Adjusting Your Trainer Difficulty | Zwift
But since the resistance doesn’t change in Erg mode anyway then something is definitely not working properly and I suspect your trainer difficulty is fine (by default I think it is in the middle)
Since you have a Pro 2, rather than an older Pro or Classic trainer then you might be able to update the firmware. To do this download the Bkool Toolkit app on your phone and connect the trainer - there should be an option to update the firmware. The latest version is 3.25 I think.
I’ve just found a page on the Bkool website about having to ‘unlock’ the Pro 2:
https://support.bkool.com/hc/en-us/articles/360034644231-Unlock-Pro-2
It seems a strange thing to need to do but it involves updating the firmware too. There is also another page which suggests you need to have the computer within 5cm(!?) of the trainer, and also to try turning the bluetooth off:
https://support.bkool.com/hc/en-us/articles/360015866012-Updating-the-trainer-firmware
Hi Sandy,
I have the good version and I did this when I bought the trainer ( 4 month ago). I have the V 3.25.
It is really strange because when I switch off the bluetooth on bkool simulator, i have the same problem as Zwift : everything is ok, I can ride, but the variation of difficulty doesn’t work.
thank you from TOURS in France
That is strange. Have you tried Bkool support to ask why it is not controllable on the Bkool SIM with Ant+? If you can fix that then it might get it working with Zwift
I sent to Bkool an email. I am waiting the answer. Yes I think this is the solution for everything.
Great, I’d be interested to know what they say and if you get it working
Same me here… until now i cannot use zwift
after i down grade the bkool os version, the ant+FC can be change. and zwift can find the bkool trainer now.
i hope bkool fix this problem so not making their customer difficult for this way around. new os should be more better and more stable.
Hi, I’ve same Hardware has you, BKoolSmartPro2
Hardware identification : 24
Firmware version : 3.25
I’m try to connect it to Samsung Galaxy Tab S4, this tablet has Ant+ inside.
On Zwift :
I can connect : ‘power’ : by Bluetooth or Ant+
I can connect : ‘cadence’ : by Bluetooth or Ant+
But can’t connect at all to ‘controllable’, so no resistance …
My BeKoolSmartPro2 works perfectly with BKool apps, but don’t know if it’s Bluetooth or Ant+.
I will try next time to connect only by Ant+ to see if I’ve same trouble has you.
Hi @MichelL,
The Bkool is currently only controllable via a Mac or PC, and then only via Ant+. Even if you have Ant+ on your android device it doesn’t currently allow for control on Zwift as far as I know. Hopefully that may change but until then you need to use a laptop or desktop
