Problem with Garmin cadence sensor in latest releases
I have been having a problem with my Garmin cadence sensor for a couple of weeks now - I think it started at about the same time as the last update. (Mac OS with an ANT±dongle)
Often, when I start riding, the cadence sensor shows really low values - it is connected, but the values are incorrect (always too low).
I have given the sensor a new battery, that didn’t help.
I can always solve the problem by going to the pairing-menu and unpair the sensor, then pair it again. Then it works fine for the rest of the session. But tomorrow, it will most likely do the same again.
Hi! were you able to solve the problem with the cadence sensor readings?
